Drop downlink data message: no payload when using downlink payload formatters
We are using a selfhosted ttn-stack-v3. Everything seems to be working well, except when we try to send a downlink using the Downlink payload formatters.
If we use the example of Downlink Encoder function from: TTN docs
We can push a download message via MQTT using
  {"downlinks": [{
    "f_port":15,
    "confirmed":false,
    "priority": "NORMAL",
    "frm_payload": "AQ=="
However, if we send the object:
  {"downlinks": [{
    "f_port":15,
    "confirmed":false,
    "payload_fields": {
    "led": true
Following the examples in TTN it should run the Downlink payload formatters, however we get this error code:
  "namespace": "pkg/applicationserver",
  "name": "no_payload",
  "message_format": "no payload",
  "code": 2
This error code is received also if we change the object ā€œpayload_fieldsā€ to any other, for example ā€œfields_payloadsā€. This is why I think we are not using the right object.
Ā· Which object must be sent to execute the Downlink payload formatters?
Ā· Are the Downlink payload formatters a functionality not ready yet?
Thank you very much.
Solved
By deeply searching in the github I arrived till this page where there are a lot of examples, so I could find the right object was ā€œdecoded_payloadā€.
  {"downlinks": [{
    "f_port":15,
    "confirmed":false,
    "**decoded_payload**": {
    "led": true
It might be useful to give more visibility to these examples in the documentation
I am actually getting this error in the application if I do not include the frame payload:
Error cause
  "name": "TypeError",
  "message": "e is undefined",
  "cause": "vc"
If I publish this with MQTT:
      "downlinks": [
          "f_port": 15,
          "decoded_payload": {
            "object_123": 123,
It works normally if I include the "frm_payload": "vu8=" as in the examples.
Any clue why? I thought the frame would be optional, but perhaps it isnā€™t?
For future reference, you have the info here: https://www.thethingsindustries.com/docs/the-things-stack/concepts/data-formats/
Wild guess: if you (only) provide decoded_payload then V3 will use your Decoder. which has an error that, in your case, throws "e is undefined". But when (also) providing frm_payload then thereā€™s no need to run the Decoder, so all is fine as far as V3 is concerned.
Iā€™d say: check your Decoder, or show its code here.
Ignore this post and read the comment below. It can stay as a reference to a wrongly written Encoder.
I was referring to the encoder, since itā€™s for a downlink. With the encoder:
function Encoder(payload, f_port) {
  var bytes = [];
  bytes[0] = payload.object_123;
  return bytes;
it gives the error from before and also this one:
drop downlink data message - invalid output of type float64
  "namespace": "pkg/messageprocessors/javascript",
  "name": "output_type",
  "message_format": "invalid output of type `{type}`",
  "attributes": {
    "type": "float64"
  "code": 2
The overview picture of a downlink without the frame and the next with a frame:
downlinks
ok, nevermind the invalid output of type float64.
bytes[0] = (payload.object_123 & 0x00FF);
and it encodes properly.
As you mention @arjanvanb if using a frm_payload the rest of the payload is ignored and all is fine.
However, if the frm_payload is not in the mqtt message, in the V3 console the first error still occurs
and I tested and the downlink is still sent correctly to the device! :grin:
Did you find the solution to the TypeError?
Iā€™m running into the same issue. My encoder function is similar to yours, first getting the drop downlink data message - invalid output of type float64 error. That was fixed by adding & 0x00FF to each value in the byte array. Now console error is
Something went wrong when displaying this event
arrow_drop_down
Show raw payload
Error cause
ā€œnameā€: ā€œTypeErrorā€,
ā€œmessageā€: ā€œundefined is not an object (evaluating ā€˜e.replaceā€™)ā€,
ā€œcauseā€: ā€œvcā€
Any idea what cause ā€œvcā€ is? I ran the encoder function through the debugger and it didnā€™t find any errors.
This topic was automatically closed after 30 days. New replies are no longer allowed.
