Has anyone worked with uplink code for this device? i have the downlink working with the example in git so that’s fine , but i cant seem to find any uplink code example? i am using ubidots with TTN."
any guidance would be appreciated.
I use uplink-commands to switch the relays and the DOuts of my LT-22222l abt once a day. Works without problems using Datacake.
You can also send uplinks by using the TTS-console. The commands can be found in the manual.
Sorry, I mixed up downlink and uplink. But also downlink works with Datacake without problems.
Ok thanks . I tried that this afternoon but getting 404 errors on downlink logs.
