Hello all,
Currently, I am attempting to connect a Dragino LSN50 sensor node to the eTape liquid level measuring sensor. The eTape is a sensor which can connect to an arduino microcontroller like so: https://idealink.net/learn/liquid-level-sensor. I am wondering if the eTape would be compatible to connect with the Dragino LSN50 sensor node. If so, what would be the pin connections to consider from the eTape to the LSN50 sensor node?
Thank you.
