Dragino LHT65N-PIR, firmware 1.4.1, thinks it has external temperature probe attached.
The response to a downlink “26 01”, FPort=5 is:
0B 0141 01 FF 0C16
0B → Temperature probe, it should be 1A
The external sensor is not a temperature probe but a PIR probe.
How does one configure proper device type using downlink command?
Have you contacted Dragino support? That should be 1st step if default behaviour of the firmware is incorrect (or their documentation wrong/not reflecting reality).
