Dear TTN-fellows,
I am currently trying to troubleshoot why my gateway shows not connected anymore, it is a dragino130 and I have a couple of those and normally do not have any problems with them. I have followed this installation guide:
Please have a look at my short summary:
- I managed to add the gateway for days already and didn’t change the packet forwarder configuration
- It has internet connection for sure and the packets of nodes are forwarded (see log below please)
- The gateway just stopped working 2h ago
sudo systemctl status lorapktfwd gives following output:
● lorapktfwd.service - packet forwarder
Loaded: loaded (/lib/systemd/system/lorapktfwd.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2020-06-17 10:52:13 BST; 11min ago
Process: 1633 ExecStartPre=/usr/bin/reset_lgw.sh start (code=exited, status=0/SUCCESS)
Main PID: 1646 (lora_pkt_fwd)
Tasks: 7 (limit: 2200)
Memory: 820.0K
CGroup: /system.slice/lorapktfwd.service
└─1646 /usr/bin/lora_pkt_fwd
Jun 17 11:03:23 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 6C 02 00 50 55 00 00 00 00 00 00 00 00 00
Jun 17 11:03:23 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 6D 02 00 58 BF 00 00 00 00 00 00 00 00 00
Jun 17 11:03:23 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 6D 02 00 60 62 00 00 00 00 00 00 00 00 00
Jun 17 11:03:23 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 6E 02 00 08 E6 00 00 00 00 00 00 00 00 00
Jun 17 11:03:23 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 6E 02 00 30 3B 00 00 00 00 00 00 00 00 00
Jun 17 11:03:23 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 6F 02 00 38 D1 00 00 00 00 00 00 00 00 00
Jun 17 11:03:23 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 6F 02 00 00 0C 00 00 00 00 00 00 00 00 00
Jun 17 11:03:23 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 70 02 00 6A BE 00 00 00 00 00 00 00 00 00
Jun 17 11:03:23 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 70 02 00 52 63 00 00 00 00 00 00 00 00 00
Jun 17 11:03:23 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 71 02 00 5A 89 00 00 00 00 00 00 00 00 00
Jun 17 10:52:01 ;raspberry lora_pkt_fwd[1027]: REPORT~ # TX errors: 0
Jun 17 10:52:01 ;raspberry lora_pkt_fwd[1027]: REPORT~ # BEACON queued: 0
Jun 17 10:52:01 ;raspberry lora_pkt_fwd[1027]: REPORT~ # BEACON sent so far: 0
Jun 17 10:52:01 ;raspberry lora_pkt_fwd[1027]: REPORT~ # BEACON rejected: 0
Jun 17 10:52:01 ;raspberry lora_pkt_fwd[1027]: REPORT~ ### [PPS] ###
Jun 17 10:52:01 ;raspberry lora_pkt_fwd[1027]: REPORT~ # SX1301 time (PPS): 782397353
Jun 17 10:52:02 ;raspberry systemd[1]: lorapktfwd.service: Succeeded.
Jun 17 10:52:02 ;raspberry systemd[1]: Stopped packet forwarder.
Jun 17 10:52:08 ;raspberry systemd[1]: Starting packet forwarder...
Jun 17 10:52:13 ;raspberry systemd[1]: Started packet forwarder.
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: Starting Packet Forwarder at 20200617095213
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:52:46 GMT ##################
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ### [UPSTREAM] ###
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets received by concentrator: 0
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets forwarded: 0 (0 bytes)
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA datagrams sent: 0 (0 bytes)
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA acknowledged: 0.00%
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ### [DOWNSTREAM] ###
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PULL_DATA sent: 3 (0.00% acknowledged)
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets sent to concentrator: 0 (0 bytes)
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # TX errors: 0
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON queued: 0
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON sent so far: 0
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON rejected: 0
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ### [PPS] ###
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # SX1301 time (PPS): 2397594
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:52:46 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:53:16 GMT ##################
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA datagrams sent: 1 (111 bytes)
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # SX1301 time (PPS): 62397685
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:53:16 GMT","lati":48.39420,"long":11.72349,"alti":441,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:53:46 GMT ##################
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA datagrams sent: 1 (154 bytes)
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:53:46 GMT","lati":48.39420,"long":11.72363,"alti":443,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:54:16 GMT ##################
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # SX1301 time (PPS): 122397761
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:54:16 GMT","lati":48.39416,"long":11.72362,"alti":442,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 00 00 00 38 DD 00 00 00 00 00 00 00 00 00
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 01 00 00 30 37 00 00 00 00 00 00 00 00 00
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 01 00 00 08 EA 00 00 00 00 00 00 00 00 00
Jun 17 10:54:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:54:46 GMT ##################
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets sent to concentrator: 0 (0 bytes)
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # TX errors: 0
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON queued: 3
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON sent so far: 0
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON rejected: 0
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ### [PPS] ###
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # SX1301 time (PPS): 122397761
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:54:46 GMT","lati":48.39411,"long":11.72361,"alti":442,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:55:16 GMT ##################
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ### [UPSTREAM] ###
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets received by concentrator: 2
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets forwarded: 0 (0 bytes)
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA datagrams sent: 1 (154 bytes)
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA acknowledged: 0.00%
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ### [DOWNSTREAM] ###
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PULL_DATA sent: 3 (0.00% acknowledged)
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # SX1301 time (PPS): 182397741
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:55:16 GMT","lati":48.39419,"long":11.72358,"alti":443,"rxnb":2,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:55:46 GMT ##################
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets received by concentrator: 0
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:55:46 GMT","lati":48.39414,"long":11.72360,"alti":443,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"rxpk":[{"tmst":228807156,"time":"2020-06-17T09:56:48.409415Z","tmms":46409,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF9BW125","codr":"4/5","lsnr":8.5,"rssi":-19,"size":20,"data":"QFwUASaA6wcBr+RDwFjMPoNMYVk="}]}
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:56:16 GMT ##################
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # CRC_OK: 50.00%, CRC_FAIL: 50.00%, NO_CRC: 0.00%
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets forwarded: 1 (20 bytes)
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA datagrams sent: 2 (405 bytes)
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # SX1301 time (PPS): 242398096
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:56:16 GMT","lati":48.39409,"long":11.72356,"alti":444,"rxnb":2,"rxok":1,"rxfw":1,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 02 00 00 60 6E 00 00 00 00 00 00 00 00 00
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:56:46 GMT ##################
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets sent to concentrator: 1 (0 bytes)
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON queued: 4
Jun 17 10:56:46 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON sent so far: 1
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:56:46 GMT","lati":48.39421,"long":11.72363,"alti":411,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":1}}
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"rxpk":[{"tmst":282555516,"time":"2020-06-17T09:57:24.157420Z","tmms":40157,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF9BW125","codr":"4/5","lsnr":9.5,"rssi":-48,"size":20,"data":"QI8YASaA4QgBXsHJqqP3/z2Ryfo="}]}
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:57:16 GMT ##################
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ ### [UPSTREAM] ###
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets received by concentrator: 1
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets forwarded: 1 (20 bytes)
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA datagrams sent: 2 (405 bytes)
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA acknowledged: 0.00%
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ ### [DOWNSTREAM] ###
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PULL_DATA sent: 3 (0.00% acknowledged)
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets sent to concentrator: 0 (0 bytes)
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # TX errors: 0
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON queued: 4
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON sent so far: 1
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # BEACON rejected: 0
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ ### [PPS] ###
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # SX1301 time (PPS): 302398303
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:57:16 GMT","lati":48.39420,"long":11.72334,"alti":395,"rxnb":1,"rxok":1,"rxfw":1,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:57:46 GMT ##################
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets received by concentrator: 0
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # RF packets forwarded: 0 (0 bytes)
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA datagrams sent: 1 (154 bytes)
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:57:46 GMT","lati":48.39409,"long":11.72362,"alti":419,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-06-17 09:58:16 GMT ##################
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: REPORT~ # SX1301 time (PPS): 362398410
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: RXTX~ {"stat":{"time":"2020-06-17 09:58:16 GMT","lati":48.39413,"long":11.72338,"alti":413,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}}
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 02 00 00 58 B3 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 03 00 00 50 59 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 03 00 00 68 84 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 04 00 00 C0 DC 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 04 00 00 F8 01 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 05 00 00 F0 EB 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 05 00 00 C8 36 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 06 00 00 A0 B2 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 06 00 00 98 6F 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 07 00 00 90 85 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 07 00 00 A8 58 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 08 00 00 A1 A9 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 08 00 00 99 74 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 09 00 00 91 9E 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 09 00 00 A9 43 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 0A 00 00 C1 C7 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 80 0A 00 00 F9 1A 00 00 00 00 00 00 00 00 00
Jun 17 10:58:36 ;raspberry lora_pkt_fwd[1646]: => 00 00 00 0B 00 00 F1 F0 00 00 00 00 00 00 00 00 00
