i am new in the topic. i would like to download data from ttn (v3) via python. I have created an ApiKey and have tried the example code from descartes https://github.com/descartes/TheThingsStack-Integration-Starters/blob/main/MQTT-to-Tab-Python3/TTS.MQTT.Tab.py.
In principle, the program starts up well and generates the following output:
Imports:
Functions:
Body of program:
Init mqtt client
Assign callbacks
Connect
Log: Sending CONNECT (u1, p1, wr0, wq0, wf0, c1, k60) client_id=b''
Subscribe
Log: Sending SUBSCRIBE (d0, m1) [(b'#', 0)]
And run forever
Log: Received CONNACK (0, 0)
Connect: rc = 0
Log: Received SUBACK
Subscribe: 1 (0,)
Log: Sending PINGREQ
Log: Received PINGRESP
ERROR:root:Caught exception in on_message: 'data_rate_index'
Log: Received PUBLISH (d0, q0, r0, m0), 'v3xxxx@ttn/devices/xxxxx/up', ... (1481 bytes)
Message: v3/xxx/devices/xxxx/up 0
"end_device_ids": {
xxxxxx
"received_at": "2023-12-24T06:29:44.829554629Z",
"uplink_message": {
"session_key_id": ".....",
"f_port": 2,
"f_cnt": 6064,
"frm_payload": "......",
"decoded_payload": {
"Ext": 1,
"Hum_SHT": 100,
"Systimestamp": 1703399375,
"TempC_DS": 327.67,
"TempC_SHT": 7.46
... here is a lot more output but ...
Log: Caught exception in on_message: 'data_rate_index'
First:
what does both error messages / exceptiona are saying to me and how to solve it?
Second:
How can i get an array (time + values) of the decoded payload (eg TempC_SHT)?
Third:
i am not sure what to do with the following line
print(os.path.basename(__file__) + " " + VER)
do i have to exchange “file” to a self chosen filename?
Last:
the program is not producing an outputfile.
Can you help?
Thanks in advance
Frank
