Hi, i am making some tests with my BL072Z board, with SF7 uplinks and downlinks are ok, but when i run the code with SF12 i only can send uplinks, in TTN i can see the scheduled downlink and in the next uplink the downlink is sent but in the BL072Z board i don’t receive anything, mi configs are:
#define OVER_THE_AIR_ACTIVATION 0
#define LORAWAN_DUTYCYCLE_ON false
#define APP_TX_DUTYCYCLE 10000
#define LORAWAN_ADR_STATE LORAWAN_ADR_OFF
#define LORAWAN_DEFAULT_DATA_RATE DR_0
#define EU868_DEFAULT_DATARATE DR_0
the default frequencies were 868100000, 868300000, 868500000 but i am using a single channel gateway working in 868100000 that is why i changed the config, if i keep the default values some uplinks are lost
* LoRaMac default channel 1
* Channel = { Frequency [Hz], RX1 Frequency [Hz], { ( ( DrMax << 4 ) | DrMin ) }, Band }
#define EU868_LC1 { 868100000, 0, { ( ( DR_5 << 4 ) | DR_0 ) }, 1 }
//LoRaMac default channel 2
#define EU868_LC2 { 868100000, 0, { ( ( DR_5 << 4 ) | DR_0 ) }, 1 }
// LoRaMac default channel 3
#define EU868_LC3 { 868100000, 0, { ( ( DR_5 << 4 ) | DR_0 ) }, 1 }
the single channel gateway also is configured with SF12
Important:
when i turn on the adaptative data rate i can receive downlinks, but with every uplink TTN sends me an empty downlink, why?
thanks.
