Hi there, I’m having issues posting a downlink messages to the downlink_url provided by TTN. I’m on the meshed network and AU915. I’ve set up the downlink integration with Tago and am seeing ‘502 Bad Gateway’ errors as the response. I’m seeing the same results with separate HTTP Post requests and curl commands.
Is this using the exact same URL that is given as downlink_url in the uplink’s JSON message? I find the /tago part at the start of the URL path a bit weird; for me (in EU868) that’s /ttn-eu instead.
Did they provide any additional details?
As this is using Meshed, @Maj may want to know about this, if this worked before.
This is my first attempt at downlinks so I don’t have any reference unfortunately. Looking on the forum I did see that first /tago/ as a region in other posts, as you suggested. I tried ‘ttn-au915’ but got a 404 so I assume that was wrong!
Randomly trying other values doesn’t make much sense. Please take a look at the downlink_url you get in each uplink’s JSON message for the HTTP Integration.
This is for the Tago integration on TTN. Tago support mentioned:
Blockquote
I just did a quick investigation on your integration with TTN. It seems that any request being made to the downlink url of your device it’s reporting Error 502: Bad Gateway… I would recommend you to check with TTN why this is happening, as it seems a very specific error on your device only.
That’s everything I got before reaching out on the forum.
Sorry for the miscommunication. I meant that I saw other forum posts mentioning downlink URLs and the format was different to what I’m seeing. Example 1, Example 2. I haven’t been able to confirm the format of the Meshed downlink URL.
Does anyone have any insights or is currently using downlinks on the meshed network? I’ve recreated all devices and still receive 502 errors on the downlink_url provided in uplink messages.
Thanks for the reply @Maj
Tago are simply displaying the downlink URL provided in the uplink message and not modifying it in any way. Is my downlink URL format correct?
I’ve not used the Tago integration before so not sure I can be of any help. We host the local TTN instance for Australia, but in terms of the Integrations we have no visibility of what they do or how they do it.
I’m doing a POST request to the HTTP integration downlink URL: curl -i -v -X POST --data "{\"dev_id\": \"ID\", \"port\":2, \"payload_raw\": \"PAYLOAD\"}" https://integrations.thethings.meshed.com.au/ttn/api/v2/down/[APP NAME]/[KEY NAME]?key=ttn-account-v2.redacted
This results in HTTP/1.1 400 Bad Request
Am I doing something incorrect in this POST request?
Also when using the Downlink URL supplied in any uplink sent to the Tago integration I get a response of HTTP/1.1 502 Bad Gateway
Any further assistance is greatly appreciated. Thanks
I was not correctly encoding as Base64. Good pickup, thank you. With that final piece the HTTP integration downlink correctly works, however the Tago integration still does not.
Is it possible the downlink URL being provided in uplink messages to the Tago integration is incorrect? Does Tago have anything to do with the URL generation or is that TTN?
