I’ll appreciate some guidance as I have been stuck for two days trying to get my first downlink message to work.
Setup:
So I have about 10 different Dragino sensors defined as End Devices in an application on TTN. The Application is using a MQTT integration with ThingsBoard. I’ve managed to create all the Payload formatters for the Uplink part, and all the data is successfully arriving in the ThingsBoard dashboard.
On the Downlink side, I followed this example TheThingsNetwork Integration.
The Class C device I am attempting to send a Downlink message to, is a LT-22222-L LoRa I/O Controller.
In the TTN Console when I schedule a Downlink message with the Payload of “05 00 11 07 D0” (via the Messaging function), then the LT-22222-L receives the message and the relays activates for 2 seconds. So I know that TTN → LT-22222-L is working.
On the ThingsBoard side, have adapted example mentioned above, and created the Downlink Data Converter. I can see that the following JSON file is sent to the TTN application, when triggered:
"topic": "v3/asgt-tb-demo@ttn/devices/a84041ba31839ccf/down/push",
"payload": {
"port": 1,
"confirmed": false,
"payload_fields": {
"type": 5,
"state": 0,
"duration1": 7,
"duration2": 208
What I can not get working or figured out, is why I can not see any downlink data arriving in my Application or Device’s “Live data” in the console.
I will really appreciate some pointers or ideas that I can try next. Or if anyone have some examples I can work through.
Thanks in advance.
Jan
