I really did not find an answer to this seeminly simple question yet (seems its time to read the complete specifications ):
What exactly does a gateway do with messages that do not belong to its own network?
Does it simply forward any LoRa packets it receives and leaves it up to the network server to decide that the packet does not belong to this network (so a rather dumb gateway forwarding everything it receives)
Or is there some intelligence on the gateway, meaning it knows which DevAddr’s belong to its own network and only forwards these messages?
Hmmm, I guess that CRC failures indeed indicate noise.
However, LoRa does not require CRC to be enabled. But LoRaWAN does, for uplinks (just like it requires specific other LoRa-settings, such as a coding rate of 4/5.)
So, CRC-less LoRa exists as well. Now, would a gateway recognize/reject a CRC-less LoRa packet…? Maybe that’s covered in Phantom Packets, which I remember being a nice read anyhow. A teaser quote and image:
If that is the case how can it be that the CRC is valid for about 70% of the phantom packets?
I remember the Phantom Packets postings - as yuo say it was a good read and good/interesting investigation by Mr. R. CRC invalid packets can be thought of as equavalent to noise for the front end…and definetly as interferers (by channel & SF), and given one has to partially process to determine if CRC failed then also represent a processing load on the system so worse than noise in impact in that it takes up a decoding/dsp/processing resourse… do CRC fails in the woods look like an unintentional DOS attack?!
Nick’s right its beer oclock and the heat is getting to me (yes I know unusual for the UK!)…
