HB9IIU
(Hb9 Iiu)
February 5, 2022, 6:58am
1
I installed my own gateway (a DLOS8) because the public one I used before was not always reachable. I then discovered that the gateway timestamp info returned in packets from end devices is wrong.
See below " “time”: “1980-01-06T00:00:50.543Z”,"
Any hint?
"received_at": "2022-02-04T21:08:18.527118528Z",
"uplink_message": {
"session_key_id": "AX7F/1d5vUJHG+NEaPGDNQ==",
"f_port": 2,
"f_cnt": 53,
"frm_payload": "y6kIhgF3AQhNf/8=",
"decoded_payload": {
"BatV": 2.985,
"Bat_status": 3,
"Ext_sensor": "Temperature Sensor",
"Hum_SHT": 37.5,
"TempC_DS": 21.25,
"TempC_SHT": 21.82
"rx_metadata": [
"gateway_ids": {
"gateway_id": "hb9iiu-jn36kl-73",
"eui": "A844A1ABCF21116C"
"time": "1980-01-06T00:00:50.543Z",
"timestamp": 113418667,
"rssi": -71,
"channel_rssi": -71,
"snr": 9.8,
"uplink_token": "Ch4KHAoQaGI5aWKLHMMIJzZrbC03MxIIqEBB//8hEWwQq8OKNhoMCMKr9o8GEIOgnpgBIPiHnsKm+gIqDAiy+9SWARDAi/aCAg==",
"channel_index": 4
kersing
(Jac Kersing)
February 5, 2022, 10:32am
2
Looks like the gateway is not able to reach a working NTP server. Is there a firewall between tha gateway and the internet blocking NTP traffic?
HB9IIU
(Hb9 Iiu)
February 5, 2022, 3:04pm
3
Good point Jac, thank you.
Nevertheless, checking the gateway log file, it seems that he gets the time properly, but is not broadcasting it.
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ ################## Report at: 2022-02-05 14:58:04 UTC ##################
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ ### [UPSTREAM] ###
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # RF packets received by concentrator: 2
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # CRC_OK: 50.00%, CRC_FAIL: 50.00%, NO_CRC: 0.00%
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # RF packets forwarded: 1 (17 bytes)
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # PUSH_DATA datagrams sent: 1 (248 bytes)
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # PUSH_DATA acknowledged: 100.00%
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ ### [DOWNSTREAM] ###
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # PULL_DATA sent: 1 (100.00% acknowledged)
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # PULL_RESP(onse) datagrams received: 1 (182 bytes)
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # RF packets sent to concentrator: 2 (12 bytes)
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # TX errors: 0
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # TX rejected (collision packet): 0.00% (req:509, rej:0)
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # TX rejected (collision beacon): 0.00% (req:509, rej:0)
Sat Feb 5 15:58:04 2022 daemon.info lora_pkt_fwd[7994]: REPORT~ # TX rejected (too late): 0.00% (req:509, rej:0)```
kersing
(Jac Kersing)
February 6, 2022, 5:20pm
4
Looks like at least syslog gets the right time. Might be a startup order thing that messes up the information obtained by the packet forwarder.
Just checked and my DLOS8 is forwarding packets with the right time at the gateway side.
"time": "2022-02-06T17:13:06.187497Z"
As I don’t own active nodes near that gateway I have no means to check what arrives at the application.
descartes
(Nick McCloud)
February 6, 2022, 5:24pm
5
What? You mean you’ve deployed a gateway without any personal benefit to yourself?
kersing
(Jac Kersing)
February 6, 2022, 6:38pm
6
About ten of them. And there are another ten waiting for a location to provide more coverage for the community.
