Sorry to bother you with this beginners questions. I’ve got the Mikrotik gateway, I’ve made a gateway in TTS, and, whatever I try, I can’t connect my Mikrotik with the gateway. Please advise.
More details required
The Mikrotik uses the Semtech UDP forwarder so you’ve configured that on both ends?
You’ve matched the EUI’s from the Lora panel to the TTS CE config?
Which Network server address are you using? The Mikrotik comes with TTI ones preconfigured, but possibly not the TTS CE (v3) EU one (I forget). You don’t want the ones ending *.industries.
