Hi
I have the IP67 conduit from Multitech
I installed the ttn packet forwarder using the tutorial from TTN
Now, I want to disable and use the forwarder of the gateway itself
I know how to stop it every time but when I restart the conduit it works by default
Can you tell me how to do it please?
my firmware is 1.4.4
I wanted to re-write the firmware
However, my firmware is 1.4.4 which is not found in the Multitech download page
The latest firmware there is 1.4.3
I think there’s a way to stop the ttn forwarder as a default, or delete it
I just don’t know the right commands to do so @kersing , could you please help in this?
I am beginner in Linux commands
I’ll try. I’m unable to test so this might not work.
I’m providing software for people to join TTN to increase network coverage, not help them leave TTN and decrease coverage. I think TTN and its community provide added value beyond what the AEP is able to provide, so why do you not want to contibute?
Cut-and-past the following commands to the Conduit command line:
update-rc.d -f ttn-pkt-forwarder remove
update-rc.d lora-packet-forwarder defaults 95 30
cat << _EOF_ > /etc/default/lora-packet-forwarder
# set to "yes" or "no" to control starting on boot
ENABLED="yes"
_EOF_
Reboot after these changes and hopefully you are set.
Thank you for your help @kersing
I did the same but replaced “lora-packet-forwarder” with “lora-network-server” in second and third lines
and it worked
as for the other matter:
I sincerely thank all who added value to the community
I myself am new to lora and the TTN community helped me a lot
The reason I can’t use TTN:
I am using it and sending data of 100+ bytes per packets per nodes each 1-3 minutes
the TTN fair policy doesn’t help in this
and I might later even abuse the duty cycle for certain tests (inside a lab in a building so it won’t be a problem)
I hope a can add more to the community later in other projects
Hi @Osman
Sorry for the late reply
I am using Multitech as a network server (Multitech gateway can be a network server itself)
And AWS cloud for application server
