[I][lorawan.cpp:214] onEvent(): EV_TX COMPLETE
135726748: engineUpdate, opmode=0x900
[I][cyclic.cpp:20] doHomework(): Measured Voltage: 4210mV
[I][cyclic.cpp:20] doHomework(): Measured Voltage: 4208mV
[I][senddata.cpp:18] SendData(): 4 bytes enqueued to send on LoRa
[I][senddata.cpp:24] SendData(): 4 bytes enqueued to send on SPI
[I][senddata.cpp:31] SendData(): Counter cleared
139359646: engineUpdate, opmode=0x908
139359657: Uplink data pending
139359660: Considering band 0, which is available at 135073657
139359691: Considering band 2, which is available at 1266243
139360027: Considering band 3, which is available at 0
139360332: No channel found in band 3
139360543: Considering band 0, which is available at 135073657
139360890: Considering band 2, which is available at 1266243
139361228: No channel found in band 2
139361438: Considering band 0, which is available at 135073657
139361785: Airtime available at 135073657 (channel duty limit)
139362132: Airtime available at 135963403 (global duty limit)
139362474: Ready for uplink
139362661: Updating info for TX at 139359657, airtime will be 3216. Setting available time for band 0 to 142575657
139363285: TXMODE, freq=867700000, len=17, SF=7, BW=125, CR=4/5, IH=0
[I][senddata.cpp:91] processSendBuffer(): 4 bytes sent to LORA
[I][senddata.cpp:99] processSendBuffer(): 4 bytes sent to SPI
139366518: irq: dio: 0x0 flags: 0x8
139366535: Scheduled job 0x3ffcdb48, cb 0x400d4f08 ASAP
139366580: Running job 0x3ffcdb48, cb 0x400d4f08, deadline 0
139366680: Scheduled job 0x3ffcdb48, cb 0x400d4d40 at 139428379
139428392: Running job 0x3ffcdb48, cb 0x400d4d40, deadline 139428379
139428506: RXMODE_SINGLE, freq=867700000, SF=7, BW=125, CR=4/5, IH=0
139430080: irq: dio: 0x1 flags: 0x80
139430093: Scheduled job 0x3ffcdb48, cb 0x400d5fcc ASAP
139430142: Running job 0x3ffcdb48, cb 0x400d5fcc, deadline 0
139430243: Scheduled job 0x3ffcdb48, cb 0x400d4d90 at 139490623
139490642: Running job 0x3ffcdb48, cb 0x400d4d90, deadline 139490623
139490749: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
139494392: irq: dio: 0x1 flags: 0x80
139494405: Scheduled job 0x3ffcdb48, cb 0x400d5ffc ASAP
139494455: Running job 0x3ffcdb48, cb 0x400d5ffc, deadline 0
139494811: engineUpdate, opmode=0x900
[I][lorawan.cpp:214] onEvent(): EV_LINK DEAD
139495271: engineUpdate, opmode=0x1920
139495494: Uplink join pending
139495668: Considering band 0, which is available at 142575657
139496015: Considering band 1, which is available at 135912132
139496362: Considering band 2, which is available at 1266243
139496698: Considering band 3, which is available at 0
139497003: No channel found in band 3
139497214: Considering band 0, which is available at 142575657
139497561: Considering band 1, which is available at 135912132
139497908: Considering band 2, which is available at 1266243
139498244: No channel found in band 2
139498456: Considering band 0, which is available at 142575657
139498803: Considering band 1, which is available at 135912132
139499151: Airtime available at 135912132 (channel duty limit)
139499498: Airtime available at 139804781 (global duty limit)
139499839: Uplink delayed until 139804781
139500073: Scheduled job 0x3ffcdb48, cb 0x400d5a34 at 139804656
139804705: Running job 0x3ffcdb48, cb 0x400d5a34, deadline 139804656
139804718: engineUpdate, opmode=0x1120
139804722: Uplink join pending
139804789: Airtime available at 135912132 (previously determined)
139805153: Airtime available at 139804781 (global duty limit)
139805495: Ready for uplink
139805684: Updating info for TX at 139804721, airtime will be 7072. Setting available time for band 1 to 140511921
139806306: TXMODE, freq=868100000, len=23, SF=8, BW=125, CR=4/5, IH=0
139813393: irq: dio: 0x0 flags: 0x8
139813410: Scheduled job 0x3ffcdb48, cb 0x400d4f24 ASAP
139813455: Running job 0x3ffcdb48, cb 0x400d4f24, deadline 0
139813554: Scheduled job 0x3ffcdb48, cb 0x400d4d4c at 140122886
140122892: Running job 0x3ffcdb48, cb 0x400d4d4c, deadline 140122886
140123013: RXMODE_SINGLE, freq=868100000, SF=8, BW=125, CR=4/5, IH=0
140129830: irq: dio: 0x1 flags: 0x80
140129843: Scheduled job 0x3ffcdb48, cb 0x400d59e8 ASAP
140129892: Running job 0x3ffcdb48, cb 0x400d59e8, deadline 0
140129994: Scheduled job 0x3ffcdb48, cb 0x400d4da0 at 140184938
140184955: Running job 0x3ffcdb48, cb 0x400d4da0, deadline 140184938
140185065: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
140193830: irq: dio: 0x1 flags: 0x80
140193843: Scheduled job 0x3ffcdb48, cb 0x400d5a10 ASAP
140193892: Running job 0x3ffcdb48, cb 0x400d5a10, deadline 0
[I][lorawan.cpp:214] onEvent(): EV_REJOIN FAILED
140194259: engineUpdate, opmode=0x1800
143117709: engineUpdate, opmode=0x1808
143117719: Uplink data pending
143117722: Considering band 0, which is available at 142575657
143117759: Considering band 1, which is available at 140511921
143118106: Considering band 2, which is available at 1266243
143118442: Considering band 3, which is available at 0
143118747: No channel found in band 3
143118958: Considering band 0, which is available at 142575657
143119305: Considering band 1, which is available at 140511921
143119652: Considering band 2, which is available at 1266243
143119988: No channel found in band 2
143120200: Considering band 0, which is available at 142575657
143120547: Considering band 1, which is available at 140511921
143120895: Airtime available at 140511921 (channel duty limit)
143121242: Ready for uplink
143121430: Updating info for TX at 143117719, airtime will be 5792. Setting available time for band 1 to 143696919
143122054: TXMODE, freq=868300000, len=17, SF=8, BW=125, CR=4/5, IH=0
143127893: irq: dio: 0x0 flags: 0x8
143127910: Scheduled job 0x3ffcdb48, cb 0x400d4f08 ASAP
143127955: Running job 0x3ffcdb48, cb 0x400d4f08, deadline 0
143128055: Scheduled job 0x3ffcdb48, cb 0x400d4d40 at 143189882
143189892: Running job 0x3ffcdb48, cb 0x400d4d40, deadline 143189882
143190009: RXMODE_SINGLE, freq=868300000, SF=8, BW=125, CR=4/5, IH=0
143191830: irq: dio: 0x1 flags: 0x80
143191842: Scheduled job 0x3ffcdb48, cb 0x400d5fcc ASAP
143191892: Running job 0x3ffcdb48, cb 0x400d5fcc, deadline 0
143191993: Scheduled job 0x3ffcdb48, cb 0x400d4d90 at 143251998
143252017: Running job 0x3ffcdb48, cb 0x400d4d90, deadline 143251998
143252125: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
143255768: irq: dio: 0x1 flags: 0x80
143255782: Scheduled job 0x3ffcdb48, cb 0x400d5ffc ASAP
143255830: Running job 0x3ffcdb48, cb 0x400d5ffc, deadline 0
143256187: engineUpdate, opmode=0x1900
