Device programming : T-Solar
Hello All,
Did you already use the T-Solar ?
Do you know how to program it using Arduino IDE for example?
Thanks !
I’d be wary of starting there. It uses the ASR6505 which is a rather odd pairing of a small STM8L processor with a very modern and not yet widely supported SX1262 radio, as a result you’re likely to have very few resources beyond the vendor and chip manufacturers themselves.
If you’re familiar with LoRaWAN and there are specific reasons you want to move to that platform, then you’re probably able to sort this out yourself.
If you’re not familiar with LoRaWAN and need tutorials, this is not where you want to start.
Also worth noting that the ASR6505’s STM8L is distinct from the ASR6501 and ASR6502’s Cypress MCU. Which is to say that this series seems to be aimed at very high volume users price shopping, not beginners.
Any updates on programming the T-solar using Arduino IDE?
You’d have to ask the manufacturer if they have any intent of supporting that.
Realistically, pick a different board which already has support.
Yes, I’ve sent a mail, but no answer from TTGO…
Any news about T-Solar Arduino support?
I use Arduino IDE to program this device. You must install the board.
Use this guide:
And this is for install Board:
https://docs.heltec.org/en/node/asr650x/htcc_am02/quick_start.html#use-arduino-board-manager
