Hello everyone,
I am trying to connect an Adafruit Lora feather 32u4 RFM9X. I followed this tutorial:
https://www.thethingsnetwork.org/labs/story/using-adafruit-feather-32u4-rfm95-as-an-ttn-node
The problem:
However the output I get on the serial monitor continuously is:
Packet queued
60890147: EV_TXCOMPLETE (includes waiting for RX windows)
VBat: 4.32
Packet queued
62271171: EV_TXCOMPLETE (includes waiting for RX windows)
VBat: 4.32
Packet queued
Nothing shows up in the console (no data), it also says that the status of the device is ânever seenâ.
What I tried:
I checked out this link where mathijs suggested the LSB and MSB first. https://github.com/matthijskooijman/arduino-lmic/issues/108
I though maybe the problem is related to range. The nearest gateway is about 500 metres away. The Adafruit page says LoRa range should be 2km with a unidirectional antenna. I am powering the device with just a USB connected to my PC (i.e. no batteries).
Code
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// LoRaWAN NwkSKey, network session key
// This is the default Semtech key, which is used by the early prototype TTN
// network.MSB!
static const PROGMEM u1_t NWKSKEY[16] = { 0xAB, 0x1A, 0xB1, 0x64, 0x37, 0xAE, 0xF2, 0xBB, 0x93, 0xB3, 0xD8, 0xBC, 0x8B, 0xC4, 0x10, 0x93 };
// LoRaWAN AppSKey, application session key
// network. MSB!
static const u1_t PROGMEM APPSKEY[16] = { 0x64, 0x09, 0x0B, 0x76, 0x6F, 0x39, 0xBD, 0x85, 0x49, 0xFB, 0xF7, 0x26, 0xD4, 0xCC, 0xB4, 0xD5 };
// LoRaWAN end-device address (DevAddr) LSB!
static const u4_t DEVADDR[4] = { 0x83, 0x19, 0x01, 0x26 } ; // <-- Change this address for every node!
// DISABLE_JOIN is set in config.h, otherwise the linker will complain).
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 20;
//// Pin mapping
//const lmic_pinmap lmic_pins = {
// .nss = 6,
// .rxtx = LMIC_UNUSED_PIN,
// .rst = 5,
// .dio = {2, 3, 4},
// Pin mapping
.nss = 8,
.rst = 4,
.dio = {7, 6, LMIC_UNUSED_PIN},
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
break;
case EV_BEACON_FOUND:
break;
case EV_BEACON_MISSED:
break;
case EV_BEACON_TRACKED:
break;
case EV_JOINING:
break;
case EV_JOINED:
break;
case EV_RFU1:
Serial.println(F("EV_RFU1"));
break;
case EV_JOIN_FAILED:
break;
case EV_REJOIN_FAILED:
break;
case EV_TXCOMPLETE:
if (LMIC.dataLen) {
Serial.println(LMIC.dataLen);
// Schedule next transmission
break;
case EV_LOST_TSYNC:
break;
case EV_RESET:
break;
case EV_RXCOMPLETE:
// data received in ping slot
break;
case EV_LINK_DEAD:
break;
case EV_LINK_ALIVE:
break;
default:
break;
//void do_send(osjob_t* j){
// // Check if there is not a current TX/RX job running
// if (LMIC.opmode & OP_TXRXPEND) {
// Serial.println(F("OP_TXRXPEND, not sending"));
// } else {
// // Prepare upstream data transmission at the next possible time.
// LMIC_setTxData2(1, mydata, sizeof(mydata)-1, 0);
// Serial.println(F("Packet queued"));
// // Next TX is scheduled after TX_COMPLETE event.
} else {
#define VBATPIN A9
float measuredvbat = analogRead(VBATPIN);
measuredvbat *= 2; // we divided by 2, so multiply back
measuredvbat *= 3.3; // Multiply by 3.3V, our reference voltage
measuredvbat /= 1024; // convert to voltage
byte buffer[8];
dtostrf(measuredvbat, 1, 2, buffer);
String res = buffer;
res.getBytes(buffer, res.length() + 1);
Serial.print("VBat: " ); Serial.println(measuredvbat);
LMIC_setTxData2(1, (uint8_t*) buffer, res.length(), 0);
void setup() {
Serial.begin(115200);
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
delay(1000);
#endif
// LMIC init
os_init();
LMIC_reset();
#ifdef PROGMEM
LMIC_setSession (0x1, DEVADDR, nwkskey, appskey);
#else
LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
#endif
#if defined(CFG_eu868)
// Set up the channels used by the Things Network, which corresponds
// to the defaults of most gateways. Without this, only three base
// channels from the LoRaWAN specification are used, which certainly
// works, so it is good for debugging, but can overload those
// frequencies, so be sure to configure the full frequency range of
// your network here (unless your network autoconfigures them).
// Setting up channels should happen after LMIC_setSession, as that
// configures the minimal channel set.
// NA-US channels 0-71 are configured automatically
LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI); // g-band
LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK, DR_FSK), BAND_MILLI); // g2-band
// TTN defines an additional channel at 869.525Mhz using SF9 for class B
// devices' ping slots. LMIC does not have an easy way to define set this
// frequency and support for class B is spotty and untested, so this
// frequency is not configured here.
#elif defined(CFG_us915)
// but only one group of 8 should (a subband) should be active
// TTN recommends the second sub band, 1 in a zero based count.
// https://github.com/TheThingsNetwork/gateway-conf/blob/master/US-global_conf.json
LMIC_selectSubBand(1);
#endif
LMIC_setLinkCheckMode(0);
LMIC.dn2Dr = DR_SF9;
// Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
LMIC_setDrTxpow(DR_SF7,14);
// Start job
do_send(&sendjob);
void loop() {
os_runloop_once();
