I have a Device listed in Applications, if I click on the Button (with the device name) the message device not found comes up and I have no chance to modify or delete it. Any hints?
BR
from the command line ?
ttnctl devices can be used to manage devices.
--app-eui string The app EUI to use
--app-id string The app ID to use
ttnctl devices delete
ttnctl devices delete can be used to delete a device.
Usage: ttnctl devices delete [Device ID]
Example
Copy
$ ttnctl devices delete test
INFO Using Application AppID=test
Are you sure you want to delete device test from application test?
yes
INFO Discovering Handler…
INFO Connecting with Handler…
INFO Deleted device AppID=test DevID=test
see - https://www.thethingsnetwork.org/docs/network/cli/api.html
