Hello
i have t T-BEAM connected to ttn. Sending datas and showing on my my map where the device is.
Is there a way to know the distanz to the Gateway?
have a nice day
vinc
First you have to know where the gateway is located. The rest can be done by some calculations or by using Google maps.
Or connect your T-beam to TTNmapper. There you can see the distance to the gateways that received your signal.
Using of RSSI or SNR is very unreliable and only a very rough estimation.
Thanks @wolfp
because i don’t know the Gateway, i hoped the device would know it to calculate!
i have tryed the ttnmapper but till now without success!
have a nice day
vinc
If you look in your RX payload you will see “rx_metadata”, all the gateways information is in there.
