hello and thank you for your feedback
We have a total of 16 gateways
Modele N° Serie Firmwear
Multitech 1 MTCDTIP2 6.3.4 don’t function
Multitech 2 MTCDTIP 22922196 6.3.4 function
Multitech 3 function
Multitech 4 MTCDTIP 22109436 6.3.4 don’t function
Mikrotic function
Multitech 6 MTCDTIP 6.3.4 function
Multitech 7 MTCDTIP2 21908792 6.3.4 function
Multitech 8 MTCDTIP 21959588 6.3.4 function
Mikrotic function
Multitech 10 MTCDTIP 22790402 6.3.4 don’t function
Multitech 11 don’t function
Multitech 12 MTCDTIP2 21900628 6.3.4 function
Multitech 13 MTCDTIP2 21901867 6.3.4 don’t function
Multitech 14 don’t function
Multitech 15 MTCDTIP2 21959590 6.3.4 don’t function
Multitech 16 MTCDTIP 21629654 6.3.4 function
Multitech 17 function
Configuring the gateway in BASIC STATION
With certificat CUPS
URI : https://eu1.cloud.thethings.network:443
The station config is the example provided by Multitech
“SX1301_conf”: {
“lorawan_public”: true,
“clksrc”: 0,
“pps”: true,
“device”: “/dev/spidev0.0”,
“chan_FSK”: {“bandwidth”: 125000, “datarate”: 50000, “enable”: true, “if”: 300000, “radio”: 0},
“chan_Lora_std”: {“bandwidth”: 250000, “enable”: true, “if”: -200000, “radio”: 0, “spread_factor”: 7},
“chan_multiSF_0”: {“enable”: true, “if”: -400000, “radio”: 0},
“chan_multiSF_1”: {“enable”: true, “if”: -200000, “radio”: 0},
“chan_multiSF_2”: {“enable”: true, “if”: 0, “radio”: 0},
“chan_multiSF_3”: {“enable”: true, “if”: -400000, “radio”: 1},
“chan_multiSF_4”: {“enable”: true, “if”: -200000, “radio”: 1},
“chan_multiSF_5”: {“enable”: true, “if”: 0, “radio”: 1},
“chan_multiSF_6”: {“enable”: true, “if”: 200000, “radio”: 1},
“chan_multiSF_7”: {“enable”: true, “if”: 400000, “radio”: 1},
“radio_0”: {“enable”: true, “freq”: 923600000, “rssi_offset”: -162, “tx_enable”: true, “type”: “SX1257”},
“radio_1”: {“enable”: true, “freq”: 922600000, “rssi_offset”: -162, “tx_enable”: false, “type”: “SX1257”},
“tx_gain_lut”: [
{“dig_gain”: 0, “mix_gain”: 11, “pa_gain”: 0, “dac_gain”: 3, “rf_power”: -6},
{“dig_gain”: 0, “mix_gain”: 13, “pa_gain”: 0, “dac_gain”: 3, “rf_power”: -3},
{“dig_gain”: 0, “mix_gain”: 9, “pa_gain”: 1, “dac_gain”: 3, “rf_power”: 0},
{“dig_gain”: 0, “mix_gain”: 10, “pa_gain”: 1, “dac_gain”: 3, “rf_power”: 3},
{“dig_gain”: 0, “mix_gain”: 12, “pa_gain”: 1, “dac_gain”: 3, “rf_power”: 6},
{“dig_gain”: 0, “mix_gain”: 10, “pa_gain”: 2, “dac_gain”: 3, “rf_power”: 10},
{“dig_gain”: 0, “mix_gain”: 11, “pa_gain”: 2, “dac_gain”: 3, “rf_power”: 11},
{“dig_gain”: 0, “mix_gain”: 11, “pa_gain”: 2, “dac_gain”: 3, “rf_power”: 12},
{“dig_gain”: 2, “mix_gain”: 12, “pa_gain”: 2, “dac_gain”: 3, “rf_power”: 13},
{“dig_gain”: 0, “mix_gain”: 13, “pa_gain”: 2, “dac_gain”: 3, “rf_power”: 14},
{“dig_gain”: 0, “mix_gain”: 15, “dac_gain”: 3, “pa_gain”: 2, “rf_power”: 16},
{“dig_gain”: 0, “mix_gain”: 10, “pa_gain”: 3, “dac_gain”: 3, “rf_power”: 20},
{“dig_gain”: 0, “mix_gain”: 12, “dac_gain”: 3, “pa_gain”: 3, “rf_power”: 23},
{“dig_gain”: 0, “dac_gain”: 3, “mix_gain”: 13, “pa_gain”: 3, “rf_power”: 25},
{“dig_gain”: 0, “dac_gain”: 3, “mix_gain”: 15, “pa_gain”: 3, “rf_power”: 26},
{“dig_gain”: 0, “mix_gain”: 15, “dac_gain”: 3, “pa_gain”: 3, “rf_power”: 27}
“station_conf”: {
“routerid”: “”,
“euiprefix”: “::0”,
“log_file”: “stderr”,
“log_level”: “INFO”,
“log_size”: 1000000,
“log_rotate”: 0
Le Server Cert :
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Gateway Key is the CUPS certificate provided by TTS
From the TTS side
I generated 2 CUPS and LNS Certificates with an operating date until 2050.
