Decoding sensor data
Im having trouble decoding the binary sensor data in the payload formatter.
I have tried various snippets of code and different variations.
This is the code in my Things Uno:
#include <Wire.h>
#include <BH1750.h>
#include <TheThingsNetwork.h>
// Set your AppEUI and AppKey
const char *appEui = "hidden";
const char *appKey = "hidden";
#define loraSerial Serial1
#define debugSerial Serial
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
#define freqPlan TTN_FP_EU868
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
BH1750 lightMeter;
void setup()
  loraSerial.begin(57600);
  debugSerial.begin(9600);
  // Wait a maximum of 10s for Serial Monitor
  while (!debugSerial && millis() < 10000)
  debugSerial.println("-- STATUS");
  ttn.showStatus();
  debugSerial.println("-- JOIN");
  ttn.join(appEui, appKey);
  Wire.begin();
  lightMeter.begin();
void loop()
  debugSerial.println("-- LOOP");
  lux = lightMeter.readLightLevel() * 100;
  byte payload[2];
  payload[0] = highByte(lux);
  payload[1] = lowByte(lux);
  debugSerial.print("Light: ");
  debugSerial.print(lux);
  debugSerial.println(" lx");
  ttn.sendBytes(payload, sizeof(payload));
  delay(1000);
The payload f
ormatter looks like:
  var data = {};
  var light = (input.bytes[0] << 8) | input.bytes[1];
  return {
    data: light / 100,
The error I get is
could not convert struct value 59.16 to map[string]interface {} for field Data: could not convert 59.16 to map[string]interface {}
When I try other variations that work, I get an empty output - {}
Im not sure where I am going wrong and have read through and tried to interpret different examples.
I appreciate your support in advance
Kind Regards
Zhivko
Check out the documentation as you’ve got a stray comma in your return structure.
And check out https://www.thethingsnetwork.org/docs/devices/bytes/ to see how you are OR’ing the two bytes rather than adding them - which may in theory work but could be ambiguous for the wonders of JavaScript.
And check out the </> on the toolbar for formatting code in your posts.
Than you for your response @descartes
I have read through the documentation which you provided a link to. It gives a very informative and detailed breakdown of bytes with references to further reading. I appreciate this.
However, it doesnt bring me any closer to figuring out what the problem is, rather it raises more questions and I have deviated further from the answer.
The main reason for posting a topic regarding this is that my head is about to explode and I’m probably missing the simplest detail, which is probably clearly obvious to many people.
I am just starting out with working with this kind of encoding/decoding. If I can see a working example, then it is easier to understand how the code is being manipulated to get a better understanding of how it works.
Right now I am going round in circles and not really understanding where I am making mistakes and just guessing.
  var light = (input.bytes[0] << 8) + input.bytes[1];
  return {
    data: {
     light: input.bytes
returns
  "light": [
    62,
    128
modified the following line:
     light: input.bytes
to
     light: light
Now it works
For refrence, I found this regarding “bitwise OR” “|”
I believe you are referring to this line
which should look like (bitwise AND) “+”
You may benefit from some of the coding tutorials online as that’s not a bitwise AND, that is an addition - you are bit shifting the first byte to make it an integer and then adding the byte. A bitwise AND is & and would be worse than doing the OR |
And the output of
light: input.bytes
given that the input.bytes is an array of bytes, is the expected array of bytes.
A little time refreshing your C skills will help with head exploding issues - no amount of working examples here can compensate for that as it usually involves CopyNPasta programming without understanding.
