Hello, I’m trying to get my Dragino Lt-22222-L up and running with “Datacake”
Everything worked flawlessly until I tried to change the Relai status from “off” to “on”.
I’m not 100% sure why this is not working but I assume it’s a problem with the network server.
I just got the server working but I’m getting an auth error.
{"code":3,"message":"error:pkg/auth:token (invalid token)","details":[{"@type":"type.googleapis.com/ttn.lorawan.v3.ErrorDetails","namespace":"pkg/auth","name":"token","message_format":"invalid token","correlation_id":"DELETED","code":3}]}
I don’t know which token is meant…
Thank you very much in advance!
