Hello to all kind strangers out there !
I am trying to install TTS as localhost on my Windows 10 computer.
I was following the tutorial video : Installing The Things Stack on Localhost - YouTube
(I used OpenSSL for the certificates, then ditched https for http)
It is basically this tutorial : Running The Things Stack | The Things Stack for LoRaWAN
Everything was going well until I had a problem when launching this command:
docker-compose run --rm stack is-db create-admin-user --id admin --email my.email@email.com
I tried reinstalling everything, tried looking everywhere for references to this error without success…
The console log is down there:
C:\Users\shine\the-things-stack>docker-compose pull
[+] Running 3/3
- postgres Pulled 2.9s
- redis Pulled 3.0s
- stack Pulled 2.5s
C:\Users\shine\the-things-stack>docker-compose run --rm stack is-db init
[+] Running 2/1
- Container the-things-stack-postgres-1 Running 0.0s
- Container the-things-stack-redis-1 Running 0.0s
init command deprecated, use migrate instead
C:\Users\shine\the-things-stack>docker-compose run --rm stack is-db create-admin-user --id admin --email my.email@email.com
[+] Running 2/0
INFO Connecting to Identity Server database...
Please enter user password:*************
Please repeat user password:*************
INFO Creating user...
ERROR Database error {"code": "undefined_table", "error": "error:pkg/identityserver/gormstore:database (database error)", "error_cause": "pq: relation \"users\" does not exist", "source": "user_store.go:154"}
go.thethings.network/lorawan-stack/v3/pkg/log.(*zapHandler).HandleLog
/home/runner/work/lorawan-stack/lorawan-stack/pkg/log/zap_handler.go:84
go.thethings.network/lorawan-stack/v3/pkg/log.(*Logger).Use.func1
/home/runner/work/lorawan-stack/lorawan-stack/pkg/log/logger.go:55
go.thethings.network/lorawan-stack/v3/pkg/log.HandlerFunc.HandleLog
/home/runner/work/lorawan-stack/lorawan-stack/pkg/log/handler.go:38
go.thethings.network/lorawan-stack/v3/pkg/log/middleware/observability.(*observability).Wrap.func1
/home/runner/work/lorawan-stack/lorawan-stack/pkg/log/middleware/observability/observability.go:86
go.thethings.network/lorawan-stack/v3/pkg/log.(*Logger).commit
/home/runner/work/lorawan-stack/lorawan-stack/pkg/log/logger.go:75
go.thethings.network/lorawan-stack/v3/pkg/log.(*entry).commit
/home/runner/work/lorawan-stack/lorawan-stack/pkg/log/entry.go:69
go.thethings.network/lorawan-stack/v3/pkg/log.(*entry).Error
/home/runner/work/lorawan-stack/lorawan-stack/pkg/log/entry.go:94
go.thethings.network/lorawan-stack/v3/pkg/identityserver/gormstore.logger.Print
/home/runner/work/lorawan-stack/lorawan-stack/pkg/identityserver/gormstore/store.go:422
github.com/jinzhu/gorm.(*DB).print
/home/runner/go/pkg/mod/github.com/jinzhu/gorm@v1.9.16/main.go:873
ERROR Database error {"code": "undefined_table", "error": "error:pkg/identityserver/gormstore:database (database error)", "error_cause": "pq: relation \"users\" does not exist", "source": "store.go:102"}
code=undefined_table
correlation_id=189044e2849e473c8137490d571a13a0
--- pq: relation "users" does not exist
Does anyone has had any similar issues? Does anyone has tips on how to solve the issue ?
My docker-compose.yml:
version: '3.7'
services:
postgres:
# In production, replace 'latest' with tag from https://hub.docker.com/_/postgres?tab=tags
image: postgres:latest
restart: unless-stopped
environment:
- POSTGRES_PASSWORD=root
- POSTGRES_USER=root
- POSTGRES_DB=ttn_lorawan
volumes:
- ${DEV_DATA_DIR:-.env/data}/postgres:/var/lib/postgresql/data
ports:
- "127.0.0.1:5432:5432"
redis:
# In production, replace 'latest' with tag from https://hub.docker.com/_/redis?tab=tags
image: redis:latest
command: redis-server --appendonly yes
volumes:
- ${DEV_DATA_DIR:-.env/data}/redis:/data
ports:
- "127.0.0.1:6379:6379"
stack:
# In production, replace 'latest' with tag from https://hub.docker.com/r/thethingsnetwork/lorawan-stack/tags
image: thethingsnetwork/lorawan-stack:latest
entrypoint: ttn-lw-stack -c /config/ttn-lw-stack-docker.yml
command: start
depends_on:
- redis
- postgres
volumes:
- ./blob:/srv/ttn-lorawan/public/blob
- ./config/stack:/config:ro
# If using Let's Encrypt:
- ./acme:/var/lib/acme
environment:
TTN_LW_BLOB_LOCAL_DIRECTORY: /srv/ttn-lorawan/public/blob
TTN_LW_REDIS_ADDRESS: redis:6379
TTN_LW_IS_DATABASE_URI: postgres://root:root@postgres:5432/ttn_lorawan?sslmode=disable
ports:
# If deploying on a public server:
- "80:1885"
- "443:8885"
- "1881:1881"
- "8881:8881"
- "1882:1882"
- "8882:8882"
- "1883:1883"
- "8883:8883"
- "1884:1884"
- "8884:8884"
- "1885:1885"
- "8885:8885"
- "1887:1887"
- "8887:8887"
- "1700:1700/udp"
# # If using custom certificates:
# secrets:
# - ca.pem
# - cert.pem
# - key.pem
# secrets:
# ca.pem:
# file: ./ca.pem
# cert.pem:
# file: ./cert.pem
# key.pem:
# file: ./key.pem
My ttn-lw-stack-docker.yml - NOTE that I’ve replaced my public IP address with 255.255 everywhere :
# Identity Server configuration
# Email configuration for "255.255.255.255"
is:
email:
sender-name: 'The Things Stack'
sender-address: 'noreply@thethings.example.com'
network:
console-url: 'http://255.255.255.255/console'
identity-server-url: 'http://255.255.255.255/oauth'
# If sending email with Sendgrid
# provider: sendgrid
# sendgrid:
# api-key: '...' # enter Sendgrid API key
# If sending email with SMTP
# provider: smtp
# smtp:
# address: '...' # enter SMTP server address
# username: '...' # enter SMTP server username
# password: '...' # enter SMTP server password
# Web UI configuration for "255.255.255.255":
oauth:
ui:
canonical-url: 'http://255.255.255.255/oauth'
is:
base-url: 'http://255.255.255.255/api/v3'
# HTTP server configuration
http:
cookie:
block-key: '' # generate 32 bytes (openssl rand -hex 32)
hash-key: '' # generate 64 bytes (openssl rand -hex 64)
metrics:
password: 'metrics' # choose a password
pprof:
password: 'pprof' # choose a password
# tls:
# source: file
# root-ca: /run/secrets/ca.pem
# certificate: /run/secrets/cert.pem
# key: /run/secrets/key.pem
# Let's encrypt for "255.255.255.255"
# tls:
# source: 'acme'
# acme:
# dir: '/var/lib/acme'
# email: 'you@255.255.255.255'
# hosts: ['255.255.255.255']
# default-host: '255.255.255.255'
# If Gateway Server enabled, defaults for "255.255.255.255":
gs:
mqtt:
public-address: '255.255.255.255:1882'
public-tls-address: '255.255.255.255:8882'
mqtt-v2:
public-address: '255.255.255.255:1881'
public-tls-address: '255.255.255.255:8881'
# If Gateway Configuration Server enabled, defaults for "255.255.255.255":
gcs:
basic-station:
default:
lns-uri: 'wss://255.255.255.255:8887'
the-things-gateway:
default:
mqtt-server: 'mqtts://255.255.255.255:8881'
console:
ui:
canonical-url: 'http://255.255.255.255/console'
is:
gs:
gcs:
ns:
as:
js:
qrg:
edtc:
oauth:
authorize-url: 'http://255.255.255.255/oauth/authorize'
token-url: 'http://255.255.255.255/oauth/token'
logout-url: 'http://255.255.255.255/oauth/logout'
client-id: 'console'
client-secret: 'console' # choose or generate a secret
# If Application Server enabled, defaults for "255.255.255.255":
as:
mqtt:
public-address: '255.255.255.255:1883'
public-tls-address: '255.255.255.255:8883'
webhooks:
downlink:
public-address: '255.255.255.255:1885/api/v3'
# If Device Claiming Server enabled, defaults for "255.255.255.255":
dcs:
oauth:
client-id: 'device-claiming'
client-secret: 'device-claiming' # choose or generate a secret
ui:
canonical-url: 'http://255.255.255.255/claim'
as:
dcs:
is:
ns:
