See the packets coming in at my own gateway (Lorix One: fw 1.3.2, with the forwarder configured as ‘LoRa Basic Station’.
station 2021-08-25 21:42:34.867 [S2E:VERB] RX 868.1MHz DR5 SF7/BW125 snr=-4.0 rssi=-115 xtime=0xA20005A7186F83 - updf mhdr=40 DevAddr=2601126E FCtrl=80 FCnt=0 FOpts= 010015D439 mic=511706318 (17 bytes)
station 2021-08-25 21:42:36.899 [S2E:VERB] RX 868.1MHz DR5 SF7/BW125 snr=-4.0 rssi=-116 xtime=0xA20005A7377883 - updf mhdr=40 DevAddr=2601126E FCtrl=80 FCnt=0 FOpts= 010015D439 mic=511706318 (17 bytes)
When I look at my gateway at TTN, I see Uplink messages like this:
“name”: “gs.up.receive”,
“time”: “2021-08-25T21:44:47.113956433Z”,
“identifiers”: [
“gateway_ids”: {
“gateway_id”: “x”
“gateway_ids”: {
“gateway_id”: “x”,
“eui”: “x”
“data”: {
“@type”: “type.googleapis.com/ttn.lorawan.v3.UplinkMessage”,
“raw_payload”: “QG4SASaAAAABABXUOc4EgB4=”,
“payload”: {
“m_hdr”: {
“m_type”: “UNCONFIRMED_UP”
“mic”: “zgSAHg==”,
“mac_payload”: {
“f_hdr”: {
“dev_addr”: “x”,
“f_ctrl”: {
“adr”: true
“f_port”: 1,
“frm_payload”: “ABXUOQ==”
“settings”: {
“data_rate”: {
“lora”: {
“bandwidth”: 125000,
“spreading_factor”: 7
“coding_rate”: “4/5”,
“frequency”: “868100000”,
“timestamp”: 2935631123,
“time”: “2021-08-25T21:44:47.098630905Z”
“rx_metadata”: [
“gateway_ids”: {
“gateway_id”: “x”,
“eui”: “x”
“time”: “2021-08-25T21:44:47.098630905Z”,
“rssi”: -116,
“channel_rssi”: -116,
“snr”: -7,
“location”: {
“latitude”: x,
“longitude”: x,
“altitude”: 17,
“source”: “SOURCE_REGISTRY”
“uplink_token”: “ChgKFgoKcml0ZWNvLWd3MRII/MI9//4PjYkQk9ro9woaCwjP85qJBhCfzaQ2ILikgIq4xgU=”
“received_at”: “2021-08-25T21:44:47.113845919Z”,
“correlation_ids”: [
“gs:conn:01FDYX2N7Y7V6KF262H7T5AW45”,
“gs:uplink:01FDZMBM89883K95F44MPW3W84”
“origin”: “ip-10-100-4-174.eu-west-1.compute.internal”,
“context”: {
“tenant-id”: “CgN0dG4=”
“visibility”: {
“rights”: [
“RIGHT_GATEWAY_TRAFFIC_READ”,
“unique_id”: “01FDZMBM892Z6GYAC12HWR72CF”
So no data comes in on the app, but if I remove the device and recreate it, a good package like this does come in:
“name”: “as.up.data.forward”,
“time”: “2021-08-25T08:35:33.023166081Z”,
“identifiers”: [
“device_ids”: {
“device_id”: “x”,
“application_ids”: {
“application_id”: “x”
“device_ids”: {
“device_id”: “x”,
“dev_eui”: “x”,
“dev_addr”: “x”
“data”: {
“@type”: “type.googleapis.com/ttn.lorawan.v3.ApplicationUp”,
“end_device_ids”: {
“device_id”: “x”,
“dev_eui”: “x”,
“dev_addr”: “x”
“as:up:01FDY76G0E83N3A6VGPAPPB8X1”,
“gs:conn:01FDXXSBZ0B71J0BJ52N43NZB9”,
“gs:up:host:01FDXXSBZP6E9PDKYKAYEX0459”,
“gs:uplink:01FDY76FSX194Z819ZDG28MM0J”,
“ns:uplink:01FDY76FSZ7R0MFDBQS5RTNJ45”,
“rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01FDY76FSZWBPHM0E406WNQ013”,
“rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01FDY76G0E1VE1ACWY2WMHTJ00”
“received_at”: “2021-08-25T08:35:33.007211056Z”,
“uplink_message”: {
“f_port”: 1,
“frm_payload”: “CasAAA==”,
“decoded_payload”: {
“digitalsensor1”: 0,
“digitalsensor2”: 0,
“temp1”: 24.75,
“temp2”: 0
“rx_metadata”: [
“gateway_ids”: {
“gateway_id”: “x”,
“eui”: “x”
“time”: “2021-08-25T08:35:04.210256099Z”,
“timestamp”: 1251937195,
“rssi”: -112,
“channel_rssi”: -112,
“snr”: -0.75,
“location”: {
“latitude”: x,
“longitude”: x,
“altitude”: 17,
“uplink_token”: “ChgKFgoKcml0ZWNvLWd3MRII/MI9//4PjYkQq5f81AQaDAjUgZiJBhD8w+j6AiD4p5bqt54C”
“gateway_ids”: {
“gateway_id”: “x”,
“eui”: “x”
“time”: “2021-08-25T08:35:06.243201971Z”,
“timestamp”: 1253972299,
“rssi”: -113,
“channel_rssi”: -113,
“snr”: -2.25,
“location”: {
“latitude”: x,
“longitude”: x,
“altitude”: 17,
“uplink_token”: “ChgKFgoKcml0ZWNvLWd3MRII/MI9//4PjYkQy7L41QQaDAjUgZiJBhDQ2Oz6AiD4mcu0v54C”
“gateway_ids”: {
“gateway_id”: “x”,
“eui”: “x”
“time”: “2021-08-25T08:35:08.274350881Z”,
“timestamp”: 1256009795,
“rssi”: -113,
“snr”: -2.25,
“location”: {
“latitude”: x,
“longitude”: x,
“altitude”: 17,
“uplink_token”: “ChgKFgoKcml0ZWNvLWd3MRII/MI9//4PjYkQw+D01gQaDAjUgZiJBhC74ZuIAyC4i5KAx54C”
“gateway_ids”: {
“gateway_id”: “x”,
“eui”: “x”
“time”: “2021-08-25T08:35:10.318736076Z”,
“timestamp”: 1258042699,
“rssi”: -116,
“snr”: -2.25,
“location”: {
“latitude”: x,
“longitude”: x,
“altitude”: 17,
“uplink_token”: “ChgKFgoKcml0ZWNvLWd3MRII/MI9//4PjYkQy+rw1wQaDAjUgZiJBhDipO6KAyD42cDJzp4C”
“settings”: {
“data_rate”: {
“lora”: {
“data_rate_index”: 5,
“received_at”: “2021-08-25T08:35:32.799525025Z”,
“consumed_airtime”: “0.051456s”,
“network_ids”: {
“net_id”: “000013”,
“tenant_id”: “ttn”,
“cluster_id”: “ttn-eu1”
“origin”: “ip-10-100-4-179.eu-west-1.compute.internal”,
“context”: {
“visibility”: {
“rights”: [
“RIGHT_APPLICATION_TRAFFIC_READ”,
“unique_id”: “01FDY76G0Z6F59BEDKDHZZRMDZ”
