i have TTN Gateway “MikroTik LoRaWAN wAP LoRa8 kit” on my roof at a height of ~25 meters
with MikroTik LoRaWAN - Omni Antenne 824-960 MHz .
As clients there are 1. channel beehive monitoring devices in my garden.
It sends on 868 Mhz SF 7 Bandwith 125 Mhz, i thins its something about 32 bits every 5 minutes.
i have tried to decrypt the Payload:
FRMPayload = 0116D7AFEB3584518DB39AEEFB5462E471936F693B (from packet, encrypted)
= 0808104410F10000FFAE000000000B00038537D92D (decrypted)
It works fine since 09.07.2023 until 01.10.2023. Then the data in the Application have stopped.
I think i know what happens.
The sender has an Problem when the fcount reachs 16382,
the sender switch to 0 or 1 and starts to count from the beginning.
So i think the is something to be fixed in the code.
I am a little confused, are the fcount and MAC the same term fo the same number?
I thought this was an ascending package number, sequence number, number of sent uplinks.
MAC normaly (Media Access Control) but in this case the “MAC state” is completely different
ist a little bit confusing.
Ok i have reset the “MAC state” must the fcnt start by 0 or 1?
which has an explicit entry for ‘reset f_cnt’ when entered in the search which leads to a section called troubleshooting as ABP f_cnt issues are sufficiently common that forum search yields dozens of hits
Hello team and I am suffering the same problem with the application not receiving the uplink message from the gateway when I power down the IOT device. Is there any other workaround ? I have tried all your ideas here with no sucess at all… Many thanks Antonio Cirone
