Dashboard Gateway Overview: Roundtrip times
what exactly is the TTN dashboard looking for to display “Roundtrip time (ms)” on the page “Gateway status”/“Gateway overview”?
Comparing two gateways (different models), one of them is displaying a RTT, the other is not with the following message instead:
This gateway still does have uplink and downlink messages though:
One difference between the gateways is that the one that DOES show RTT has a GPS connected and is transmitting class B beacons, which the other one has/does not. Is this a requirement to show RTT?
Gateway SHOWING RTT:
Gateway NOT showing RTT:
  1. If you do not use Class B devices it is better to disable the beacons. While transmitting a beacon the gateway can not receive uplinks so using beacons effectively reduces the uplink capacity of the gateway.
  2. GPS/Beacons are not related to RTT. The package forwarder and the protocol used to connect to TTN determine whether RTT can be calculated. The message regarding downlinks is misleading.
Good thought on the class B beacons. I’m in a very low traffic area, so far I’m alone on my gateway and I’m not using class B myself.
This makes me feel a lot better about my primary gateway not having class B capability in the first place (only my “experimental” does.) :slight_smile:
Thanks!
