I am setting up a private lora network (not LoraWAN) in the 868MHz range, and I am wondering if it is possible to set 3 Gateway channels in the g3 (869.4 – 869.65 MHz): 10% band with 125KHz Bandwidth?
For example:
1: 869.4
2: 869.525
3: 869.65
What is the minimum margin possible between frequencies?
How does the bandwidth affect the legal limitations?
Yes, but if you compare with LoRaWAN regulations, the frequencies has a margin between them of a certain value. How has this been determined? (as its almost “international”).
