Still struggling with the ‘missing records’…
From time to time I do miss a message from my sensor in my application. I have setup some logging 'see extract below) . In the log of my gateway I see the following which I try to understand :
My sensor is sending a message exactly every 5 minutes : 16:32:21 - 16:37:21 - 16:42:21 - 16:47:21
How to explain that “FCnt” is succeeding : 6062 - 6063 - 6064 - 6065.
But the “DevAddr” of 6064 is different (“4C0BBD9F” <> ?? “260BBD9F”). And there is no RXTX record after FCnt 6064.
Is this due to TTN, my gateway (Dragino LPS8) or my sensor (Dragino LDDS75)? Any tips where I should take some action ?
---------------------------------------------------------------------------------------------------------------------- extract of my log
Thu Jul 1 16:32:21 2021 daemon.info lora_pkt_fwd[31129]: PKT_FWD~ DATA_UNCONF_UP-> {“DevAddr”: “260BBD9F”, “FCtrl”: [“ADR”: 1, “ADRACKReq”: 0, “ACK”: 0, “RFU” : “RFU”, “FOptsLen”: 0], “FCnt”: 6062, “FPort”: 2, “MIC”: “3E19F1C0”}
Thu Jul 1 16:32:21 2021 daemon.info lora_pkt_fwd[31129]: RXTX~ {“rxpk”:[{“tmst”:2203323947,“time”:“2021-07-01T15:32:21.855716Z”,“chan”:2,“rfch”:1,“freq”:868.500000,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“lsnr”:3.8,“rssi”:-90,“size”:18,“data”:“QJ+9CyaArhcC6zd6asjA8Rk+”}]}
Thu Jul 1 16:37:21 2021 daemon.info lora_pkt_fwd[31129]: PKT_FWD~ DATA_UNCONF_UP-> {“DevAddr”: “260BBD9F”, “FCtrl”: [“ADR”: 1, “ADRACKReq”: 0, “ACK”: 0, “RFU” : “RFU”, “FOptsLen”: 0], “FCnt”: 6063, “FPort”: 2, “MIC”: “F522C341”}
Thu Jul 1 16:37:21 2021 daemon.info lora_pkt_fwd[31129]: RXTX~ {“rxpk”:[{“tmst”:2503329467,“time”:“2021-07-01T15:37:21.869432Z”,“chan”:3,“rfch”:0,“freq”:867.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“lsnr”:6.8,“rssi”:-89,“size”:18,“data”:“QJ+9CyaArxcCNMkWzvVBwyL1”}]}
Thu Jul 1 16:37:21 2021 daemon.info lora_pkt_fwd[31129]: INFO~ [up] PUSH_ACK received in 31 ms
Thu Jul 1 16:37:24 2021 daemon.info lora_pkt_fwd[31129]:
Thu Jul 1 16:42:21 2021 daemon.info lora_pkt_fwd[31129]: PKT_FWD~ DATA_UNCONF_UP-> {“DevAddr”: “4C0BBD9F”, “FCtrl”: [“ADR”: 1, “ADRACKReq”: 0, “ACK”: 0, “RFU” : “RFU”, “FOptsLen”: 0], “FCnt”: 6064, “FPort”: 2, “MIC”: “BEE51382”}
Thu Jul 1 16:42:25 2021 daemon.info lora_pkt_fwd[31129]:
Thu Jul 1 16:42:25 2021 daemon.info lora_pkt_fwd[31129]: REPORT~ ################## Report at: 2021-07-01 15:42:25 UTC ##################
Thu Jul 1 16:47:21 2021 daemon.info lora_pkt_fwd[31129]: PKT_FWD~ DATA_UNCONF_UP-> {“DevAddr”: “260BBD9F”, “FCtrl”: [“ADR”: 1, “ADRACKReq”: 0, “ACK”: 0, “RFU” : “RFU”, “FOptsLen”: 0], “FCnt”: 6065, “FPort”: 2, “MIC”: “0437526B”}
Thu Jul 1 16:47:21 2021 daemon.info lora_pkt_fwd[31129]: RXTX~ {“rxpk”:[{“tmst”:3103343451,“time”:“2021-07-01T15:47:21.880536Z”,“chan”:2,“rfch”:1,“freq”:868.500000,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“lsnr”:4.2,“rssi”:-90,“size”:18,“data”:“QJ+9CyaAsRcCJgyo30prUjcE”}]}
Thu Jul 1 16:47:21 2021 daemon.info lora_pkt_fwd[31129]: INFO~ [up] PUSH_ACK received in 31 ms
Thu Jul 1 16:47:25 2021 daemon.info lora_pkt_fwd[31129]:
Thanks in advance,
Rgds
Piet De Bruyn
