Connection problems with TTGO T-Beam and Heltec Wireless Stick
Hi, I have the Heltec Wireless Stick board as a receiver and the TTGO T-Beam board as a sender. The problem is reading the sender data in the receiver, for now it is a number but solving it I want to send temperature, GPS location and measure the maximum distance. I’m newbie at this so maybe i can’t send between two different boards :frowning_face:
Sender code (TTGO T-Beam)
//Libraries for LoRa
#include <SPI.h>
#include <LoRa.h>
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
//433E6 for Asia
//866E6 for Europe
//915E6 for North America
#define BAND 915E6
//packet counter
int counter = 0;
void setup() {
  //initialize Serial Monitor
  Serial.begin(115200);
  Serial.println("LoRa sender");
  //SPI LoRa pins
  SPI.begin(SCK, MISO, MOSI, SS);
  //setup LoRa transceiver module
  LoRa.setPins(SS, RST, DIO0);
  if (!LoRa.begin(BAND)) {
    Serial.println("LoRa has failed");
    while (1);
  Serial.println("LoRa has started");
  delay(2000);
void loop() {
  Serial.print("Packet ");
  Serial.println(counter);
  LoRa.beginPacket();
  LoRa.print(counter);
  LoRa.endPacket();
  counter++;
  delay(2000);
Receiver code (Heltec Wireless Stick)
#include "heltec.h"
//433E6 for Asia
//866E6 for Europe
#define BAND    915E6
String LoRaData;
void setup() {
  Heltec.begin(true /*DisplayEnable Enable*/, true /*Heltec.LoRa Disable*/, true /*Serial Enable*/, true /*PABOOST Enable*/, BAND /*long BAND*/);
  Heltec.display->drawString(0, 0, "LoRa receiver");
  Serial.println("LoRa receiver");
  Heltec.display->drawString(0, 12, "LoRa has started");
  Heltec.display->display();
  Heltec.display->clear();
  delay(2000);
void loop() {
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    Serial.print("Received packet '");
    Heltec.display->drawString(0, 0, "Received packet ");
    while (LoRa.available()) {
      LoRaData = LoRa.readString();
      Serial.println(LoRaData);
      Heltec.display->drawString(5, 10, LoRaData);
    int rssi = LoRa.packetRssi();
    Serial.print("' with RSSI ");
    Heltec.display->drawString(0, 20, "with RSSI ");
    Serial.println(rssi);
    Heltec.display->drawString(10, 20, String(rssi));
Nicely formatted first post. However this forum is only for LoRaWAN on TTN and this appears to be about a point to point application.
Hello, sorry for that, if you want delete the topic
Make sure you don’t try to connect this device to TTN as disruptive to others… your more than welcome back when you get a full LoRaWAN gateway or if you use a LoRaWAN library (not lora.h !) to get your T-Beam online through other people’s gateways… this device is successfully used by other TTN’ers :slight_smile: :+1:
Connecting LoRa P2P to TTN would be no mean feat …
