Connection p2p with two RN2483 and LoRaWan gateway
Hello all,
I have tried to connect two RN2483 devices ( mounted on a TTU board) to my LoRaWan gateway (Kerlink IOT station), the connection went successful through setting up the nodes as abp, however, in order to test the LoRaWan stack I would like to send something from one node to the other, I have read here that there are two possibilities, one is just testing the LoRa modulation and the other the whole stack.
That last case is the one I would be interested on, so I was wondering if someone could enlight me a bit concerning to that point. So far I can send out data from one node to the LoRaWan gateway, nevertheless I don’t see that message being received into the second node.
I have been looking the reference manual from RN2483 rn2483.pdf (362.3 KB) so as to find a commnand that read the data given from LoRa stack and not just at LoRa modulation level (command Serial1.println(“radio rx 0”)) but I cannot find it. Any suggestions?
Thanks in advance,
regards!
You have to use IQ inversion the correct way. Take a look at the command manual, it describes a bit how to use is.
radio iqi on/off
oh, that was not the question… I don’t think you can interfere with the LoRaWAN protocol inside the RN2483. You should use the raw lora modulation (or (g)fsk) with ‘radio’ commands.
To use just the Lora stack you must send the “mac pause” command and then you can use “radio rx 0”.
To return to LoraWAN mode you must send “mac resume”.
If you are going to use radio rx 0 you can set “radio set wdt 2000” to set the timeout to wait for a rx packet. If you plan to do continuous reception you should set “radio set wdt 0”.
I’ve test it and works fine. Remember that if you are using LoraWAN in (adr) Adaptive Data Rate the radio will retain the last channel settings,
@a.valero I don’t really get you, as far as I understood using mac pause means that you do not use LoRaWan stack and mac resume means you do use LoRaWan stack (according to rn2483.pdf (362.3 KB) page 22)
Thus in briefly my tx should be something like below, if I send a FF ?
Serial1.write("mac pause ");
Serial1.write(“radio tx FF”);
being the receiver something like
Serial1.write(“mac pause”);
Serial1.write(“radio set wdt 0”);
Shouldn’t I use the command radio rx 0 instead of the one that set the window?
Thank you very much
Hi again, I have coded this small receiver and transmitter, however I am struggling becuase I don’t see in my receiver what supposed being sent.
TX side where message is a string (HI)
text = "Node " + nodeAddress + " sending: " + message + "\n";
Serial.print(text);
//using the LoRa modulation to reach other node instead the LoRaWan stack
//stopping the LoRaWan stack on the device
Serial1.write("mac pause\r\n");
Serial1.write("radio tx 1");
Serial1.print(message);
Thus in the serial I got
Node 103 sending: HI
My RX is
int rx = 0;
  Serial1.begin(57600);
  while (!Serial1);
  Serial1.println("mac pause\r\n");
  //setting window to zero
  Serial.print("Setting radio window: ");
  Serial1.println("radio set wdt 0\r\n");
  //setting the rx to continous mode of reception
  Serial1.println("radio rx 0\r\n");
  if (Serial1.available() > 0) {
    // read the incoming byte:
    rx = Serial1.read();
    // say what you got:
    Serial.print("Comming to node " + nodeAddress +" serial: ");
    Serial.println(rx);
The output I get is
> Comming to node 102 serial: 52
but that value changes over time, so I am receiving something that I should not, maybe should I clear the buffer before receiving?
Thanks in advance!
Sample sequences:
To transmit:
Serial1.write(“mac pause\r\n”);
// check answer 0-4294967295\r\n
Serial1.write(“radio tx FF\r\n”);
// check answer ok\r\n
// check answer radio_tx_ok\r\n or radio_err\r\n
Serial1.write(“mac resume\r\n”);
To enable receive mode during 1 second (any packet size)
Serial1.write(“radio set wdt 1000\r\n”);
Serial1.write(“radio rx 0\r\n”);
// the module waits for an RX packet during a maximum of 1 second
// if a packet arrives you will read radio_rx \r\n : hexadecimal value secuence
// if no packet arrives after 1 second read radio_err\r\n
To enable receive mode during 1 second expecting a 10 bytes packet
Serial1.write(“radio rx 10\r\n”);
// if a 10 bytes packet arrives you will read radio_rx \r\n : hexadecimal value secuence
Transmit 1 packet and the wait during 1 second for any size RX packet
// if no packet arrives after 1 second read radio_err\r\n (timeout)
To read use better
Serial1.readBytesUntil(’\n’, buffer, length)
HI @a.valero, I have followed your tip and it is the same, I don’t get the message back,I am quite puzzled by the fact that the answer to radio tx is none of the standard values, but a number is that normal?
TX is now
  String text = "Node zero";
  String e = "zero";
  text = "Node " + nodeAddress + " sending: " + message;
  Serial.println(text);
  Serial.print("Pausing mac: ");
  e = Serial1.write("mac pause\r\n");
  Serial.println(e);
  Serial.print("sending to radio: ");
  e = Serial1.write("radio tx 1\r\n");
  Serial.println(e);
whose outcome is
Node 02010102 sending: HI
Pausing mac: 11
sending to radio: 12
LoRa status:
Pausing mac: 11
LoRa status:
RX is now
  String str;
  char rx[2];
  int e = -1;
  while (!Serial1);
    Serial1.readBytesUntil('\n', rx, 2);
    Serial.print("Comming to node " + nodeAddress + " serial: ");
    Serial.println(rx);
and the outcome
Comming to node 02010103 serial: 42
Comming to node 02010103 serial: 94
Comming to node 02010103 serial: 96
Comming to node 02010103 serial: 72
Comming to node 02010103 serial: 45
Comming to node 02010103 serial: %
If you use Serial1.println(“mac pause\r\n”);
it includes the \r\n so you should use Serial1.println(“mac pause”); instead.
Serial1.write(“mac pause\r\n”); is the same as Serial1.println(“mac pause”);
e = Serial1.write(“radio tx 1\r\n”);
Serial.println(e);
The value for e should be 12 as is the len of “radio tx 1\r\n”.
To read the answer from the module this method is not correct:
Serial1.readBytesUntil(’\n’, rx, 2);
You should use this:
char rx[20];
int len;
len = readWaitLn(rx, sizeof(rx), 100);
Add this two functions:
uint16_t readLn(char* buffer, uint16_t size)
int len = Serial1.readBytesUntil(’\n’, buffer, size);
buffer[len - 1] = ‘\0’; // bytes until \n always end with \r\n, so get rid of both
return len;
// Waits for a string. Returns true if the string is received before a timeout.
// Returns false if a timeout occurs or if another string is received.
uint16_t readWaitLn(char* buffer, uint16_t size, uint16_t timeout)
unsigned long start = millis();
uint16_t len;
while (millis() < start + timeout) {
if ((len = readLn(buffer, size)) > 0)
return len;
// timeout
return 0;
HI @a.valero thank you very much for your time, still struggling with it though… I don’t understand one thing, what is the timeout value depending on? Why should it be 100? THen the radio window has to match with it right?
I have tried your code as this
RX
char rx[20];
  int leng ;
  while (!Serial1);
  Serial1.write("radio rx 0\r\n");
  leng =  readWaitLn(rx, sizeof(rx), 100);
  Serial.println(leng);
Outcome
11
11
11
11
11
11
11
11
11
11
TX
  String e = "zero";
  delay(50);
  while (Serial1.available()) Serial.write(Serial1.read());
  Serial.println(e);
   Serial1.println(message);
   Serial.println(message);
output, as you see the value 12 is there, I checked out the string and it says radio_tx_ok
Node 02010102 sending: hi
Pausing mac: 4294967245
hi
try this:
char rx[20];
int leng ;
while (!Serial1);
Serial1.println(“radio set wdt 0\r\n”);
if (leng) Serial.println(rx); //should read ok
while(1)
if (leng) Serial.println(rx); //should read 4294967295
while(!leng)
leng = readWaitLn(rx, sizeof(rx), 1000); // wait message for 1 second
if (leng) Serial.println(rx); //should read the message
You have this post here that explains how to do P2P with RN2483:
http://openlora.com/forum/viewtopic.php?f=5&t=6
Hello All,
I would just warn - be aware that the radio commands in RN2483 are there really for test set ups. There is no real ‘protocol’ as such wrapped around this. No frequency agility, no duty cycling, no acknowledges etc. It works, but all those things needed to make it a robust legal system are all moved up to the application level, and you’ll need to work that out.
Its all possible, but just be aware …
With standard LoRaWAN all this has been worked out for you by the big founder members of the LoRa Alliance.
Good luck,
JDP
HI @sergiosena, I have followed the configuration that you provided in your link,in my both TTU. One is acting as rx and the other as tx as I mentioned in the answer to @a.valero , however, I got the same answer, I don’t get the sent menssage at all in the rx, still wondering why…
@JDP, thanks for your reply, I understand it, my real intention involves a LoRaWan gateway, in order to make use of LoRaWan stack, I was trying to test p2p with this device, but for now unluckly
thanks,
LoRaWAN specification states that the transceiver may handle any other protocols when not actually doing LoRaWAN. You should then still keep to the duty cycle limit. However, I think RN2483 is not made for this purpose because it is not possible to read out the current duty cycle counter or ask the module if it is doing LoRaWAN stuff or let it interrupt radio commands. You have to implement this yourself.
You have to set the frequency, header info and some more settings of the radio the same on both modules. The radio will have the same settings as when it left LoRaWAN mode.
radio set mod/freq/pwr/sf/crc/iqi/cr/wdt/bw
Thanks scle, I think I have already done it following the instructions that @sergiosena gave in his link, RN2483 is configured with the following parameters in both devices. I don’t get an error when setting them so I assume that they are correct.
Thanks again
“radio set mod lora”
“radio set freq 868000000”
“radio set pwr 14”
“radio set sf sf12”
“radio set afcbw 125”
“radio set rxbw 250”
“radio set fdev 5000”
“radio set prlen 8”
“radio set crc on”
“radio set cr 4/8”
“radio set wdt 0”
“radio set sync 12”
“radio set bw 250”
thanks again!
IQ-inversion (iqi) is also an important setting for radio to radio communication
Check out this link: http://openlora.com/forum/viewtopic.php?f=12&t=887
It might be the reason why you don’t receive anything. Keep in mind that RN2483 uses SX1276 as chipset for communication.
Hi scl, I have set the iq inversion in both devices as on, still nothing is coming to my RX… I am running out of ideas, and starting to dislike this platform XD
Hi ndarkness,
Do you have a log of the serial conversation?
