Connection Mikrotik lr8 to TTS
these are my first steps in LoRaWAN. I bought the Mirotik Lr8 and tried to connect it to TTS. I did all my settings in Winbox for the Gateway and also create my gateway in TTS.
But as you can see in my Log there are still Warnings and in TTS the Gateway status is: Disconnected.
Can you imagine what i need to change in my settings or what the problem may be?
Let me now, if you need some more informations to answer my questions.
Thanks a lot
Lukas
Screenshot 2022-03-04 112747
Welcome
What port are you using?
Your time stamp gives me the idea you are not connected to the net.
https://www.thethingsindustries.com/docs/gateways/adding-gateways/
Thans for you fast responding.
this are my Firewalls rules and the up and down port of TTS EU
Screenshot 2022-03-04 131636
Screenshot 2022-03-04 131757
I Hope this can help you.
Not resolving a DNS entry is usually about the lack of the DNS setup …
