IOT-CFC
(Iot Cfc)
May 6, 2020, 5:15pm
1
Dears,
I have an issue to connect to tnt with node red “tnt uplink” (or ttn event or ttn uplink)
ttn Gatway receive the data from lorawan device
Data are available in the application
I can send the data by integration and retrieve with “Mqtt in”
But “tnt uplink” never connect the best i have is “connecting”
I suppose is related to ID/Key access (I red all I can found on the subject like : https://github.com/TheThingsNetwork/nodered-app-node/blob/HEAD/docs/quickstart.md ).
I red and applied all I can found on the subject like :
## Quickstart
This quickstart will walk you trough the usage of the TTN node-red nodes for
listening to device uplinks and events, as well as sending downlink in response.
### Setting up the environment
1. Make sure you have [Node.js](https://nodejs.org/) installed.
2. Install Node-RED using `npm`:
```bash
npm install node-red -g
See Node-RED's [Getting Started / Installation](http://nodered.org/docs/getting-started/installation) for details.
3. Install the TTN Node-RED nodes:
```bash
cd $HOME/.node-red
npm install node-red-contrib-ttn
This file has been truncated. show original
I have three Access key Default, app, home (link to the captor configuration)
Any help appreciate
rabeb
(Rabeb)
August 8, 2021, 4:45pm
2
hello sir
i have the same problem i want to ask you if you found a solution how to fix it
it will be great if you can share it with us
jezd
(JD)
August 8, 2021, 11:01pm
3
Just use the standard MQTT nodes for connection to TTN v3 as this is the preferred method - there is a guide and lots of info on this forum (search mqtt ttn v3), as for node-red-contrib-ttn (node) - Node-RED it is NOT supported anymore so please don’t use it.
