I am currently trying to send data to TTN by LoRa WAN. I want to forward data from esp32 T-Beam node to RAK 7268 gateway which will then forward the data to TTN.
So far, the examples I found from the Heltec-Esp32 library are for esp32 s3 and not for esp32. Has anyone here been able to connect their device to TTN through a gateway? What library have you used?
My TTGO T-Beam has SX 1278 chip and has worked with LoRa p2p before so i can confirm the device is working. I have connected my RAK node with the gateway to send data to TTN so can confirm the gateway is fine too.
I have tried the library that you mentioned after trying to run an example, it produces a compilation error regarding an ‘object’ within the code. I cannot seem to figure out how to fix it. I have added the necessary keys to the program and assigned the proper region too.
In file included from C:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2024618-10468-j8p1xz.ugxff\LoRaWAN_Starter\LoRaWAN_Starter.ino:25:
C:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2024618-10468-j8p1xz.ugxff\LoRaWAN_Starter\config.h:129:19: error: 'radio' was not declared in this scope
129 | LoRaWANNode node(&radio, &Region, subBand);
C:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2024618-10468-j8p1xz.ugxff\LoRaWAN_Starter\LoRaWAN_Starter.ino: In function 'void setup()':
C:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2024618-10468-j8p1xz.ugxff\LoRaWAN_Starter\LoRaWAN_Starter.ino:34:19: error: 'radio' was not declared in this scope
34 | int16_t state = radio.begin();
C:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2024618-10468-j8p1xz.ugxff\LoRaWAN_Starter\LoRaWAN_Starter.ino: In function 'void loop()':
C:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2024618-10468-j8p1xz.ugxff\LoRaWAN_Starter\LoRaWAN_Starter.ino:52:20: error: 'radio' was not declared in this scope
52 | uint8_t value1 = radio.random(100);
exit status 1
PS, nothing connects to a gateway, you connect to the LoRaWAN network server - the gateway has no brains to connect to.
I am a beginner to this so thank you for clarifying.
Which Arduino-ESP32 board package are you using and I can investigate. I live with the RadioLib tester so shouldn’t be much to debug the situation for you.
PS, I’ve removed the rude word in the title, please don’t use the M word again, we can’t afford to be picked up by Google searches!
Sorry, should have been clearer, it’s which version of the Arduino-ESP32 BSP - we have been using v2 whilst we wait for the very new v3 to settle down so I don’t know what the current status of v3 is but I can check.
