Hie everyone,
It since a week, that Im fighting to get traffic from my gateway lg01-p, to TTN.
It is connected to Internet, and to TTN, but no traffic from the node.
I followed this tutorial:
http://wiki.dragino.com/index.php?title=Connect_to_TTN#Create_Single_Channel_Gateway_By_LG01
I’ve created the directory /root/data, and I’ve executed the lg01_pkt_fwd. everything works fine.
I followed all the steps, and I’ve tried also, the one of the dragino manual, nothing works.
Trying with the lmic, library or rf95, it doesn;t work, and I don’t know what to do.
Assuming you are trying to activate a device and that is not working then it may be the activation method. I believe that the default OTAA option requires at least a 2 channel gateway (your unit being a single channel gateway). Try using the ABP activation method.
I followed steps in this tutorial ( http://wiki.dragino.com/index.php?title=Connect_to_TTN ) and try to connect the LG01 Gateway to TTN. But in TTN console it showing not connected status. What I need to check please let me know.
Hello, I created a gateway in TTN but it still does not connect, I did the steps in the tutorial http://wiki.dragino.com/index.php?title=Connect_to_TTN#Create_Single_Channel_Gateway_By_LG01 but it has not given connection.
I am in Colombia, I use the frequency 915MHZ and the router.us.thethings server; I’m missing so there is connection.
Thanks.
The Dragino LG01 is not a LoRaWAN gateway.
See: Single Channel Packet Forwarder - Not gateway [guidelines]
