Hi Shulti,
We need to start some service to start the gateway?
I have internet connection from gateway.
Some idea??
Many thanks !!
Paulo
Hi Shulti,
Some idea??
Many thanks !!
Paulo
Hi allā¦.It is already connected
The process was not running.
What I checked before:
All configuration was ok.
So I follow this link :
https://www.thethingsnetwork.org/docs/gateways/troubleshooting/semtech-udp.html#gateway-not-detecte
1 - I check that program is not running see āEnsure the packet forwarder is runningā
2 - Then I tried to find what i must to do to run the process.
I found this file: /etc/iot/scripts/lg01_pkt_fwd
And run like this:
/etc/iot/scripts/lg01_pkt_fwd&
After 2, 3 minutes it was connected to TTN.
I hope that this help someone.
Now that is connected, another stepā¦I will try to see some packets traffic
Paulo
In the latest firmware update LG01P has mqtt support, has anyone used their native mqtt offline yet?
Helps me to active my gateway! Thnx!
Just received my Dragino LG01 and Iām having troubles.
I followed the tutorial (and I already built a gateway with a rpi+ic880 so I am ok with LoRawan basics) + applied suggested patch in this topic (I had to start lg01_pkt_fwd script and I created root/data folder) and I finally got a āconnectedā status on TTN channel. All firmware (MCU + Atheros) are up to date. But I donāt like the syslog :
Tue Jul 24 07:56:21 2018 kern.notice syslog: [IoT]: DNS Resolve Check: FAIL
Tue Jul 24 07:58:17 2018 kern.notice syslog: [IoT]: Internet Connection Check: FAIL
Tue Jul 24 07:58:19 2018 kern.notice syslog: [IoT]: DNS Resolve Check: FAIL
Tue Jul 24 07:58:29 2018 daemon.err uhttpd[1891]: ls: /dev/ttyUSB*: No such file or directory
Tue Jul 24 07:59:32 2018 daemon.err uhttpd[1891]: ls: /dev/ttyUSB*: No such file or directory
Tue Jul 24 08:00:00 2018 cron.info crond[1838]: USER root pid 4350 cmd checkdog
Sun Jan 1 00:00:05 2012 cron.err crond[1838]: time disparity of -3450719 minutes detected
Sun Jan 1 00:01:57 2012 kern.notice syslog: [IoT]: Internet Connection Check: FAIL
Sun Jan 1 00:01:59 2012 kern.notice syslog: [IoT]: DNS Resolve Check: FAIL
And obviously, GLOBAL led stays off.
Three things : no internet connection detected (but ping command are ok) and the ntp simply seems to crash and I cannot get my node connected (which works well with my rpi+ic880 gtw). I also canāt see the uart dialog between mcu and atheros (running ātelnet localhost 6571ā command from SSH terminal).
For the NTP issue I forced to reach fr.pool.ntp.org and it seems to work better.
Any idea ?
I was seeing similar errors on mine before however, I was not getting a connected status on TTN at the time so if you are seeing yours as connected perhaps the issues are different. I havenāt checked my syslog since Iāve gotten mine running and connected but Iāll have to do so when I get home later today. I can at least confirm that the Global LED on mine was at the very least on the last time I had looked at the gateway last evening.
Iāll have to report back to you when I have access to gateway.
Ok I think I found the issue. So first, I only tested ABP to eliminate potential downlink problem. So apparently, in EU868 frequencies are rolling to minimize radio band use and so minimize duty cycle (correct me if Iām wrong). So for a mono-canal gateway itās a big problem ā¦ So forcing my node to use only one frequency (868.1MHz in my case) solved the problem. Almost all packets are received (some times one is missing, I guess the gateway is busy by another node in the building).
Here my discussion about the node part : https://github.com/GrumpyOldPizza/ArduinoCore-stm32l0/issues/26
EDIT : I found the solution for lg01_pkg_fwd script that do not start automatically. In the iot-deamon file (which is start on boot) we found this :
#Check What Service we use
service=`uci get iot-services.general.server_type`
if [ "$service" != "disabled" ];then
script_name=`uci get $service.general.routine_script`
script=$IOT_DIR$script_name
# Kill possible running daemon;
servpid=`ps w| grep $script | grep -v grep | awk '{print $1}'`
if [[ ! -z "$servpid" ]]; then
killall $script_name
fi
#start services
#check script type
if [ "${script%.lua}" != "$script" ]; then
lua $script &
else
$script 2>&1 > /dev/null &
fi
fi
The problem is that there is no lorawan.general.routine_script configured. The fix is simple : edit /etc/config/lorawan and add option āroutine_script ālg01_pkt_fwdāā to config āsettings āgeneralāā and reboot
EDIT #2 : I found another bug ā¦ SF11 and SF12 are not supported and the SF settings sent to TTN server are wrong. I know that because I compared with my ārealā gateway. It shows that my node is correctly configured but LG01 seems to receive nothing when Dragino is configured SF11 or SF12, I donāt know why ā¦ And when itās received (with SF7 to SF10) itās not well reported : real SF7 is reported as SF12BW125. Real SF10 is reported as SF7BW125 ā¦
EDIT #3 : ā¦ suddently SF are well reported to TTN server ā¦ without doing anything ā¦ strange ā¦ but SF11 and SF12 still not working
Iām issuing the same problem as labsud. Every frame with SF11 or SF12 never appear into gateway traffic. And as you can see, the same frame as seen in the gateway trafic, and in the application data donāt show the same SF
Into gateway traffic:
"gw_id": "eui-xxxxxxxxxxxxxxxx",
"payload": "xxxxxxxxxxxxxxxxxxxxxxxxxxxx",
"lora": {
"spreading_factor": 9,
"bandwidth": 125,
"air_time": 185344000
"coding_rate": "4/5",
"timestamp": "2018-07-31T15:56:06.240Z",
"rssi": -46,
"snr": 7.8,
"dev_addr": "xxxxxxxx",
"frequency": 868100000000000
Into application data:
"time": "2018-07-31T15:56:05.923526878Z",
"frequency": 868.1,
"modulation": "LORA",
"data_rate": "SF10BW125",
"gateways": [
"gtw_id": "eui-xxxxxxxxxxxxxxxx",
"timestamp": 859898932,
"time": "2018-07-31T15:56:04.782568Z",
"channel": 5,
"rssi": -128,
"snr": -15,
"latitude": 45.xxxxx,
"longitude": 5.xxxxx,
"altitude": 2xx
... other gateway but not dragino-lg01...
Because of the error in SF on gateway traffic, the gateway doesnāt appear into the application data.
This problem emerge only with some SF, I still havenāt test them all, and I may update a list of the buggy ones.
Joris
Is there a fix for this problem? So, I have the same problem.
Which one are you issuing? both?
I havenāt find any fix, sorry. Here or there ( [LG01] Same packet, twice in application console ) I get no solutionā¦
It is neccessary to remove also āwww.google.comā from the host list. Google refuse the usage of ICMP against the site. Just pick another website - check with fping before - which allows the ICMP
Can anyone help me to connect Dragino getway and Dragino shield to TTN? and transfer data through them.
what did you try yourself ? what problems did you encounter ? which dragino gateway ? what firmware version ?
Dragino gateway LG01-P
Firmware version 4.3.4
I have connected my LG01 to TTN but as I am not able to connect to dragino shield I can not able to transfer data. I want to know how can I connect dragino shield with the gateway and able to transfer data. I am new to lora network so I do not have sufficient knowledge.
Hello RobinLoRa
Just the last day I installed allso a LG01-P and is right now connected to the TTN network as active gateway.
I have followed the Wiki off Dragio http://wiki.dragino.com/index.php?title=Connect_to_TTN#Create_Single_Channel_Gateway_By_LG01
I donās use the LG01-p as router:
So disable under network internet acces:
And then under network - Lan & DHCP give a static Ip and cancel DHCP-server
then you must use the latest Arduino sketch : but read for that the topic in the wiki " Upload Arduino Sketch to LG01 Linux System"
And then it will be online
Johan
Hi there!
how do we create that directory?
I have a similar problem, but in my case in the gateway TTN part it shows the data traffic, coming from the device, but on the device part it says that it is connected and says the number of frames up but doesnt show any dataā¦
Ad first you should read all info above, with the serveral links to documentation. I have followed it and it works after the latest reboot.
But you reply on message from Schulti and just a few rows/postās below you could find the right answere.
but if you still run in trouble you could better āstart over and go to start againā and follow the information in this thread. Read from top >> down.
regards
i tried this and didnt workā¦ Can you explain why you did this and why would this work?
Often if you do a lot off small thingās you donāt remeber what you did.
Thats why I Said. Game over and start again with a clean setting.
so try to rest the device to factory, and start over to make the settingās mentiond above.
I have done it with all info above, with out error 's so the settingās or good.
But I you walk to a error please remember that you search first and then come with your question form what is not working. add some details and not alone āit is not workingā
Good luck with starting from a fresh install.
One thing I would say, itās a ONE channel gateway and not a fully 8 channel gateway like the gateways from TTN , so with standard out off the box LoRa deviceās will connect once in de 8 requestās.
