Following https://www.thethingsnetwork.org/docs/gateways/multitech/aep.html
to configure Multitech IP67 gateway to TTN. I am getting this error when trying to connect to the gateway with puTTy:
Network error: connection refused
I’ve enabled DHCP and it looks like the IP address for the gateway network is 169.254.89.90.
Any help is appreciated:)
Scott
An address starting with 169.254 means that the gateway did not get a response from the DHCP server.
You’re welcome. What’s simple for one person might be much less simple for someone else
