Hi I’m quite new with LoRa and TTN.
I’ve been facing some issues with the HTTP Integration.
I’m trying to create a new HTTP integration without success, I’m in Portugal and I had tested this integration with two requester as requesbin.net and rbaskets.in/web without success, and I don’t obtain any data communication in TTN.
OK, surreal, I’d strongly recommend you understand the concept of an application (like soil temperature & moisture levels) and a field with 15 devices all measuring that, sending in data, channeled through the application and on to your integration:
Once you’ve done that, you’ll understand a whole heap more and I can tell you how to fake a device.
But really, having a device is like, the whole point. And if you are no where near a gateway (check the home page of The Things Network, scroll down for the map), a gateway as well.
