I have two TTN Accounts and I´d like to move all my gateways from Account 1 to Account 2.
I found two ways doing this but none of them works.
Currently I am trying the way over the CLI (the other possibility is via the API).
The link to the documentation is:
https://www.thethingsindustries.com/docs/gateways/concepts/gateway-claiming/
I think I can make the gateway from Account 1 claimable because I get a new API-Key and a notification by Email.
But the command for claiming always throws an error.
I am using the command where I should replace the <gateway-id> but obviously this string is not even given by the command:
ttn-lw-cli gateways claim <gateway-eui> --authentication-code <claim-authentication-code> --user-id <user-id> --target-gateway-id [target-gateway-id]
I was playing around with this command with no success.
Does anybody have an Idea how to use this command or another solution?
