Does anyone have a global.json configuration file for the Cisco Lorawan gateway working on AU915?
We have a number of gateways using AS923 and are considering switching.
No, but I’d guess that if you take a look at a generic file for your existing band and see how it compares to the one you are currently using that should provide sufficient guidance to make any needed format / version changes to a generic AS923 config file to make it compatible with your gateway.
