With the codes I could change the settings for this node and it works now with my TTN gateway, but it sends the data every 20 minutes. I like to change that to 5 or 10 minutes. But I could not find the AT code in their manual to change this. Maybe I looked over it, but when somebody can help me.
Have you tried 5.28 AT+RTP:GetorSetrecordtimeperiodinmin
in https://www.dragino.com/downloads/downloads/LHT65/UserManual/DRAGINO_LHT65_AT_Commands_v1.0.pdf#page26 ?
thanks! not yet, but will do that this evening. thank you again.
received this message from Edwin;
You can use the AT Command; AT+TDC=600000 which is 600s, 10 minutes.
Or use downlink command: 01 00 02 58 0x258 = 600(s)
thank you all
