I can’t change my email for my account on eu1.cloud.thethings.network (EU1 Community).
It’s possible to change it in edit box (Profile settings/General settings/Email address) only for one session, after logout and login again there is still old one.
Changing your email address is indeed a bit messy right now, since we’re still in the process of migrating account management from our old V2 Account Server to our new “The Things ID” system.
If you go to https://account.thethingsnetwork.org/, you should be able to change your email address. The next time you sign in to The Things Stack Community Edition, it should update your email address.
I raised a similar issue on on 1/11/22 on Slack ‘support’, as this is the process advised on this forum.
There has just been a reply (on Slack) saying that you need to access your account from the right web address, access it from the wrong location and you may not be able to edit the details that you can see.
Not had a chance to check the ‘solution’ provided, but it seems to me that support for such issues via slack ‘could be improved’ …
You can access when logged into any of the main sites pages (main .org front page, community, learn, etc. ) - click on your user icon top right, select “My Profile” then click on the pencil next to your user name…under Profile Picture you will then see “account settings” - that also then takes you to the id.thethings… web page where you edit your address…
So just to clarify a bit - account management on The Things Network goes via https://id.thethingsnetwork.org/ - not via the account page on The Things Stack
The reason for this is that you have a singular account for every place on The Things Network (forum, website).
I see from your earlier message ( that you are trying to do edits directly from The Things Stack, but this is blocked because management (password / email) needs to go via https://id.thethingsnetwork.org/
