I’m using CayenneLPP protocol to send readings from my node device to TTN. This CayenneLPP implementation, LINK.
Can I send multivalue readings over CayenneLPP? I know that I can send separate messages one after the other, but in one message to have more readings of the same sensor. For example, the same temperature measured at different time intervals.
Does CayenneLPP support timestamp for each/group of readings? In the case where my device measure readings rarely than sending it over LoRa.
I’m not sure if this forum is the best place for asking this questions, but it seems to me that is rarely place where I will get an answer, thanks
