We successfully set up an end node that sending data to TTN, but right now I’m stuck with a downlink messages issue. We need to set up a working downlink to have the ability to control relays on our sensor from the Web-page.
What we are using:
Sensor:
Arduino Mega + Dragino Shield + sensors + relays
TX over OTAA works nice
Gateway:
Dragino lg308
Usually sensor in coverage of one more somebody else gateway
After sending the downlink request to TTN, I’ve got a message in the TTN console that the downlink is scheduled but that’s all, sensors not receiving any data, and the message looks like not going to the gateway.
I am trying to debug using integrated into lg308 gateway firmware LoRa logger, but the log is unclear for me
I think the TTN console gateway log would be helpful but for some reason in the TTN stack version log not working for some people (like me) all over the world as well as the gateway offline status issue, I found a TTN article about that.
I am attaching screenshots maybe they would be helpful:
Any advice or support on how I can debug downlink would be very appreciated
Attaching my end node code:
Code
static uint8_t mydata[] = “OTAA”;
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 60;
// Pin mapping for Dragino Lorashield
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 9,
.dio = {2, 6, 7},
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F(“EV_SCAN_TIMEOUT”));
break;
case EV_BEACON_FOUND:
Serial.println(F(“EV_BEACON_FOUND”));
break;
case EV_BEACON_MISSED:
Serial.println(F(“EV_BEACON_MISSED”));
break;
case EV_BEACON_TRACKED:
Serial.println(F(“EV_BEACON_TRACKED”));
break;
case EV_JOINING:
Serial.println(F(“EV_JOINING”));
break;
case EV_JOINED:
Serial.println(F(“EV_JOINED”));
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print(“artKey: “);
for (int i=0; i<sizeof(artKey); ++i) {
Serial.print(artKey[i], HEX);
Serial.println(””);
Serial.print(“nwkKey: “);
for (int i=0; i<sizeof(nwkKey); ++i) {
Serial.print(nwkKey[i], HEX);
Serial.println(””);
Serial.println(F(“Successful OTAA Join…”));
// size, we don’t use it in this example.
LMIC_setLinkCheckMode(0);
break;
|| case EV_RFU1:
|| Serial.println(F(“EV_RFU1”));
|| break;
case EV_JOIN_FAILED:
Serial.println(F(“EV_JOIN_FAILED”));
break;
case EV_REJOIN_FAILED:
Serial.println(F(“EV_REJOIN_FAILED”));
break;
break;
case EV_TXCOMPLETE:
Serial.println(F(“EV_TXCOMPLETE (includes waiting for RX windows)”));
Serial.println(F(“Received ack”));
if (LMIC.dataLen) {
Serial.print(F(“Received “));
Serial.print(LMIC.dataLen);
Serial.println(F(” bytes of payload”));
// Schedule next transmission
break;
case EV_LOST_TSYNC:
Serial.println(F(“EV_LOST_TSYNC”));
break;
case EV_RESET:
Serial.println(F(“EV_RESET”));
break;
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F(“EV_RXCOMPLETE”));
break;
case EV_LINK_DEAD:
Serial.println(F(“EV_LINK_DEAD”));
break;
case EV_LINK_ALIVE:
Serial.println(F(“EV_LINK_ALIVE”));
break;
|| case EV_SCAN_FOUND:
|| Serial.println(F(“EV_SCAN_FOUND”));
|| break;
case EV_TXSTART:
Serial.println(F(“EV_TXSTART”));
break;
default:
break;
void do_send(osjob_t* j){
Serial.println(F(“OP_TXRXPEND, not sending”));
} else {
Serial.println(F(“Packet queued”));
Serial.print(F("Sending packet on frequency: "));
Serial.println(LMIC.freq);
void setup() {
Serial.begin(115200);
Serial.println(F(“Starting”));
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
delay(1000);
#endif
#if defined(CFG_au921)
Serial.println(F("Loading AU915/AU921 Configuration..."));
#endif
// LMIC init
os_init();
LMIC_reset();
LMIC_setDrTxpow(DR_SF7, 14);
LMIC_selectSubBand(1);
do_send(&sendjob);
void loop() {
os_runloop_once();
Thank you!
