Thanks @filipgDSE but I would like to use TTN/TTS.
I now have it working.
First of all, I followed the instruction as written, and created ttn-lw-cli.yml config as above:
oauth-server-address: ‘https://eu1.cloud.thethings.network/oauth’
identity-server-grpc-address: ‘eu1.cloud.thethings.network:8884’
etc
$ ttn-lw-cli gateways claim authorize my-gateway-id
This failed with:
parse “‘https://eu1.cloud.thethings.network/oauth’”: first path segment in URL cannot contain colon
Fix: Remove quotes on every line of the file.
This failed with:
error:cmd/ttn-lw-cli/commands:unauthenticated (not authenticated with either API key or OAuth access token)
Fix: Run ttn-lw-cli login, open the link provided in Firefox and login. You will get the following message in the browser: “The CLI successfully got an access token. You can now close this window and return to the CLI.”
API key provided (didn’t need do anything with this). Power cycled gateway, and waited a few minutes - it’s now connected!
So these are the step by step by instructions to claiming a gateway which has been deleted TTN v2 and added to TTN v3 (aka The Things Stack Community Ediition), but remain disconnected.
Install the CLI on Linux:
$ cd ~
$ mkdir ttn
$ nano ttn/ttn-lw-cli.yml
Copy & paste the following in to the file:
oauth-server-address: The Things Network Account
identity-server-grpc-address: eu1.cloud.thethings.network:8884
gateway-server-grpc-address: eu1.cloud.thethings.network:8884
network-server-grpc-address: eu1.cloud.thethings.network:8884
application-server-grpc-address: eu1.cloud.thethings.network:8884
join-server-grpc-address: eu1.cloud.thethings.network:8884
device-claiming-server-grpc-address: eu1.cloud.thethings.network:8884
device-template-converter-grpc-address: eu1.cloud.thethings.network:8884
qr-code-generator-grpc-address: eu1.cloud.thethings.network:8884
Save the file and exit.
$ export TTN_LW_CONFIG=/home/myname/Desktop/ttn/ttn-lw-cli.yml
$ ttn-lw-cli login
Open the link provided in Firefox and login:
https://eu1.cloud.thethings.network/oauth/authorize?client_id=cli&redirect_uri=local-callback&response_type=code
You will get a message in the browser indicating successful login and you can return to the command line.
|INFO|No API Key provided. Creating one
|INFO|Created API Key with ID: OJRNVEKPFNNXXXXXXXXXXXXX
Gateway no authorized for claiming.
Return to The Things Network Console
Click ‘Claim Gateway’
Enter the EU ID (same as my existing gateway), Gateway ID (I chose a new one but I think the same would be ok from @KrishnaIyerEaswaran2’s post above.
Gateway claimed successfully.
Power cycle TTIG gateway and wait for initialisation sequence to complete.
Solid green LED shown.
Wait a few more minutes, refresh the page and you should see Status ‘Connected’ on the Gateways page.
Thanks to @descartes and @KrishnaIyerEaswaran2 for the support.
I would definitely recommend a review of those instructions @KrishnaIyerEaswaran2. They jump all over the place, assume a lot of implied knowledge and in some cases are just plain wrong.
Regards
Richard.
