Hello, I am trying to add Tektelic Kona Micro Gateway with UDP Packet Forwarder to TTN Community Edition.
I configured the gateway using this guide.
The EUI of the gateway is 647FDAFFFE0059B2
Despite of that that gateway is working, its status on TTN is Disconnected.
How could I debug this issue to make gateway online?
cslorabox
(Cslorabox)
2
Are there any nodes sending transmissions which the gateway is picking up?
You may need to figure out how to check the gateway’s own internal logs.
descartes
(Nick McCloud)
3
Firstly I’d search the forum for the numerous other versions of this issue.
But also explain what you mean by “working” when you are saying it’s disconnected …
