Can't access TTN Console, ttnctl fails, TTN Node-RED library fails, and Kickstarter gateways get stuck after daily reboot
Im in France, Same for me, cannot access console.
same here in the UK-
Is there a way for us to tell TTN about this problem? Or do they monitor this forum?
I am in Germany, btw. Have a nice Sunday!! :slight_smile:
https://status.thethings.network/
somes services are degraded
Ah! Thanks for sharing this link. Yes, the NOC problem may be what is causing this.
See The Things Network Status Page [HowTo].
Yesterday I installed my new gateway and now I wanted to check.
  • I can’t access the “gateway” page
  • the system says ÿou don’t have a gateway"
  • the console page only shows devices, the gateway page keeps saying “initializing”
By the remarks above I assume the issue is with the server and not withme and has not been solved yet?
Yup, I think you are correct.
Same here in Spain.
Though TTN Console is great for debugging (especially to debug OTAA Join problems, or to see the gateway’s Traffic page when one does not have access to the gateway’s raw logs), many of us simply don’t need it every day as more reliable alternatives exist:
Same issue!
Same thing in the US. Data is still coming through via MQTT but I can’t access the console for configuration and such
Hi all was up but now down and cant access here in the UK What are the issues if look at fault status show all workig except instability in MQTT :slightly_frowning_face:
I can access applications - but gateway settings stuck at “fetching gateways”.
Also some gateways disappered on the map.
(north germany)
No access to GWs and some of them no traffic at all :frowning:
Check thethingsnetwork.slack.com -> ops channel
console seems to be down complete - getting this now:
502 Bad Gateway
nginx
Those are old messages
The same for me now. 502 bad gateway. I can not enter to the consoel.
502 bad gateway. the servers behind the nginx instance are down.
please fix it fast.
