Cannot connect new The Things Kickstarter Gateway to V3
Hello all,
This is my first post in the community, so bear with me and please let me know if my etiquette doesn’t meet community guidelines. I’m also new to the world of LoRa and cloud services in general, so this has been a bit of an uphill journey for me.
I’m trying to set up The Things Kickstarter Gateway (Note: NOT a TTIG) to a The Things Stack Community Edition-hosted console (NAM1). I’ve followed the steps outlined at The Things Kickstarter Gateway Registration several (read: dozens) of times, but have been unsuccessful in setting up my gateway on the console. I am able to connect to the WiFi, but am unable to activate past that. In my most successful runs, I cycle between the WiFi setup stage (one LED solid, one slowly blinking) and the activation stage (two LEDs solid, one slowly blinking).
The only thing I can see that I didn’t quite follow in the instructions was the addition of a tenant ID after my gateway ID. However, anytime I try to put this into the configuration page, I get an error (see below).
My gateway is brand new and out of the box. I also downloaded the most recent firmware to make sure it was up to the 1.0.8 standard. I’ve also tried a couple different console setups and WiFi networks and have met the same problems each time. Alls to say I don’t think this is a hardware or console issue; I believe it is purely a configuration problem. However, I am finding no help in the documentation understanding what I am doing wrong. Can anyone in the community help me figure this out?
I’ve attached a copy of the UART debug I received during one of my configurations with areas of interest highlighted. This run was done with the credentials “swri-div-14-gnat-asset-tracker” and the network ID “https://nam1.cloud.thethings.network/” over an Ethernet connection. Any help will be greatly appreciated!
Attempts at Registration Forum.pdf (234.1 KB)
Check Want to move my TTN Gateway to V3 - #9 by aberenyi for instructions that worked for another forum user.
Thanks for the response. These were the instructions I was trying to follow. However, any combinations of my gateway key followed by an “@ttn” results in the “unexpected data sent to gateway” error I received above. I have tried using the tenant ID with two different API keys as well.
Please try with a smaller (less characters) gateway id. You might well be running into buffer size limits concerning the name used.
All,
Just wanted to post my resolution for anyone else with similar issues. There were several steps I had to take to find a solution to my problem.
  1. I did in fact need a tenant ID (@ttn) for my gateway.
  2. My original gateway ID was too long, and this was indeed why I got the “unexpected error” issue.
However, this was not the end of my problems. I was still getting the frustrating looping problem and rejected LoRa packets. I did finally manage to find some links tracing this back to a mechanical issue. This led to resolution #3:
  1. Push my LoRa chip firmly into its socket – and pushed it even harder when that didn’t work
– to FINALLY get a working router.
Thank you for all the help Kersing and other members of the community for having the answers that support and the setup page did not. So much for a five minute activation.
Am trying to migrate my old Kickerstarter GW to TTNv3. With the experience as you summed up in this thread I was hoping that it would go smooth. However it seems the gw is not connected
  • The 3rd LED keeps blinking slowly (which means activating) - restarting the gw does not help
  • Have Wiffi and ethernet connected
  • Info (http://192.168.1.68/info) states the following
So I am puzzled where the problem is?
Finally the kickstarter gateway connects to the network (when I do not configure WiFi it ‘activates’).
Now the 4 LEDs all light up.
However I see no LoRa traffic in the v3 console (while there is traffic flowing thru the air).
Seems like a hw issues to me
I think I have a similar problem, everything looks good on the gateway info page, but no traffic at all showing on the TTN v3 console. Shows as connected but up/down counters are 0/0, there is a node nearby:
Yes that is the same as I am seeing (http://192.168.1.69/info)
While in the console no traffic is seen
imho if the connection between the gateway and the TTS CE-server gets lost for more than 60(?) seconds this counter is reset to zero.
Does your gateway send status messages every 30 seconds?
With one of my gateways I observed that if the WLAN-connection gets lost even for a short time this counter is reset to zero.
After factory reset of the kickstarter GW I configured as described in lnks above.
So I do not know it is is send every 30 secs. Never had issues on v2 so I am puzzled what the reason is :slight_smile:
Well, at least the screenshot now shows “Gateway Card: 868MHz”, so it’s detected, and “config: correct” and “Broker connection: true”. This wasn’t the case in your earlier screenshot, so I think you’re heading in the right direction.
Yes @bertrik - it started working when I did not configure WiFi / to me it seems a weird problem :slight_smile:
What a mess, I feel sorry for people who bought this gateway, and would not recommend it to anyone.
Like @jeroen2 I’m running from one weird problem into another:
  • The screen shot at The Things Kickstarter Gateway | The Things Stack for LoRaWAN shows old/misleading info, is not applicable for TTS CE
  • On my best attempt, according to the internal info page of the gateway, things look OK: LoRa card detected, LoRa packets received, gateway claims to be connected to a network and is able to connect to the gateway server. However no data on the console and no evidence it is passing traffic from nearby nodes.
  • However, after having enabled wifi, the “gateway card” status goes to “ND” (not detected?), no more packets coming in
Not sure anymore what to do, hopefully someone from TheThingsIndustries can look into this.
I finally got it working. I tried various things.
The thing that finally made it work is to remove the “@ttn” from the gateway id, just enter the plain gateway id in as shown in the TTS CE console. This is in direct contrast to an earlier post from june 24 in this thread.
Thanks. That also worked for me. So do not use the @ttn behind the Gateway Id:
(at least for the kickstarter gateway)
I am still not able to configure WiFi - > after doing so it does not connect to ttnv3 anymore
So I thought I would leave this as a bread crumb for the next person trying to move their kickstarter gateway to V3
I started yesterday morning moving my gateway from V2 to V3. I read the background info and figured it would be a 15 min task. 6 hours later I was ready to chuck it into the trash bin. The GW is using 1.08 firmware, is US model (TTN-001-915-1.0) and is located in the US.
The issue is that it is stuck at the 3rd LED fast blink
I’ve read and reread all of the forum posts, reread the docs, reset the GW (full serial flash) numerous times, added and deleted gateway (using unique IDs each times), created and deleted API keys but no change
This morning I attached a HW serial monitor to inspect the GW messages. This line looks suspicious
CONF: Could not parse URL ‘nam1.cloud.thethings.network/’, fallback on default
I can ping https://nam1.cloud.thethings.network/ so it isn’t a DNS issue. In the end it was a missing “HTTPS://” in the on the setup page
ttn setup
The source of the error was I was copying and pasting the link from the address setup page (Addresses | The Things Stack for LoRaWAN). On that page all URLs are preceeded with https:// except the #$%^$&^% API endpoint links
2
Once that was fixed the gateway finally connected
I think all my configuration are now correct with all the info which is given here but still it isn’t working. It looks like the gateway card is not detected if I look to the info page. I have reinserted the card but this did not the trick. It is currently do a reboot after an uptime from 99 seconds. Has anyone a suggestion how to troubleshoot this?
Here also the UART output…
* The Things Network *
* G A T E W A Y *
Firmware name: AmazingAckermann, type: 0, version: 1.0.8, commit: 846da98b, timestamp: 1574945235
Bootloader revision: 1, commit: 7167873a, timestamp: 1496411298
Build time: Nov 28 2019 12:48:18
Reboot reason: 0x10
BOOT: (persisted info) 6F 72 72 65 01 03 DB 59 ED 3E FF 5D 48 F4 58 E5
WIFI: Entering state 0
WIFI: Entering SCAN state 0
MAIN: Initialisation complete
LORA: Changing state from 0 to 0
MAIN: Leaving state 0
MAIN: Entering state 1
FLASH: Magic bytes found: wifi config present
FLASH: Magic bytes found: activation data present
FLASH: Magic bytes not found: no stored FOTA data present
FLASH: Loading Firmware Data
CNFG: (Firmware HASH (sha256)) F7 4B 6E FA 9E 91 AE E4 2C 62 8E D2 50 1B 43 3C C0 69 36 41 AA 52 86 F7 67 0F 44 7A 6E FD 25 F2
FLASH: Loading WiFi Data
CNFG: WiFi SSID: Things-Gateway-001EC03AEF18
CNFG: WiFi key: ***
CNFG: WiFi conn_type: 4
CNFG: WiFi sec_type: 4
FLASH: Loading Activation Data
CNFG: Gateway ID: iotutrneude
CNFG: Gateway Key: ***
CNFG: Account Server URL: https://eu1.cloud.thethings.network
CNFG: Locked: true
CNFG: Locked first time: false
MAIN: Leaving state 1
MAIN: Entering state 2
INET: State change to 0
LORA: Initialisation complete
LORA: Changing state from 0 to 1
WIFI: Entering state 1
ETH: IP Address: 0.0.0.0
WIFI: Entering state 2
WIFI: Disabling modules
Head magic match void: trying to free an already freed block, ignore
WIFI: Entering state 3
WIFI: Enabling modules for server
WIFI: Entering state 6
>WIFI: IP Address: 192.168.84.1
SNTP: State change from 0 to 1
INET: Gateway has Ethernet
INET: State change to 2
INET: Connected to a network, waiting for DHCP lease, checking validity with ping
CB: ETH: IP Address: 192.168.10.152
SNTP: State change from 1 to 2
SNTP: State change from 2 to 3
SNTP: State change from 3 to 4
INET: State change to 3
INET: Ping probe
INET: Error sending probe on WiFi
INET: Ping response from PIC32INT, set as default
INET: State change to 4
SNTP: State change from 4 to 5
SNTP: State change from 5 to 6
SNTP: State change from 6 to 7
INET: State change to 5
MAIN: Leaving state 2
MAIN: Entering state 3
CNFG: Load online user config state change to 4
HTTP: Close active socket 0
HTTP: Starting connection
LORA: Wait init complete, waiting for application.
LORA: Changing state from 1 to 2
MON: SYS Stack size: 3959
MON: TCPIP Stack size: 3815
MON: APP Stack size: 4290
MON: LoRa Stack size: 3909
MON: heap usage: 183KB (188KB), free: 156KB
MON: TCPIP Stack size: 3620
MON: TCPIP Stack size: 3601
SCAN LENGHT: 0
MON: heap usage: 183KB (190KB), free: 156KB
SCAN LENGHT: 0
MON: TCPIP Stack size: 3589
