Installation was successful and I can create new applications but when I try to add end devices I always get the same error no matter which LoRaWAN version or any other parameter I set.
See screenshot for error message I get from console trying to post/put the new device:
Seems like there are field_mask values that are added even if they shouldn’t be there. It is an OTAA device I try to add and not a multicast.
The version of The Things Stack installed is v3.10.7 since this is the version that was used in the installation guide.
I was afraid that this would be the case. The installation of The Things Stack I have in Azure, from following the guide mentioned in my first post, is not setup using docker on a Ubuntu VM but has the stack running native as a deamonand is using the Azure Redis service as well as an Azure PostgreSQL managed db so I am a little unsure what I need to do to update to a newer version.
Are there any guides for this type of setup, I couldn’t find any in the TTN documentation library?
There are no official guides for your type of deployment, but maybe @kartben can add a little “Upgrading” chapter to his guide. It’s probably mostly the same as for our Docker-based deployment, but with slightly different commands.
I’m guessing that as long as there are no major database migrations that needs to be done it would be a small task of upgrading just the stack on the Ubuntu VM but hopefully @kartben can shine some light on this before I get started and mess things up
I gave it a shot and downloaded the latest stack, 3.14.0, as a .deb to my Azure Ubuntu VM. Installed it using the same command as in the cloud init file from @kartben, sudo dpkg -i, and from the result of this operation the previously installed stack with version 3.10.7 is now updated to 3.14.0.
After this operation I couldn’t access the console any more so I have now tried a bunch of different operations to get it running including the command to register console as an OAuth client:
Secrets are pulled from Azure Keyvault so I get the same as when doing the initial installation with 3.10.7.
Still I can’t access the console. Is there anything more that needs to be done after having upgraded to a newer stack version?
Following the official TTN guide which is using docker seems to run pretty much the same commands as I have done.
