– (1) is not a problem. Branch " dual_chan_pkt_fwd_up_down" contains LoraModem.c, but branch “master” doesn’t contain the file. So it seems we don’t need it.
– For (2), “sudo systemctl status dual_chan_pkt_fwd -l” seems not to work. I tried following command, but didn’t work and showed error message shown below.
It’s OK, take your time. Now it’s not an urgent issue. I deleted installed files,
and download and re-install files again. Now it’s working. I don’t know why,
what’s wrong. Please let me know if you have any information. It’s going to
be helpful for next installation.
I have some questions.
1- does the raspberry pi hat supports the raspberry pi 4 model?
2- is it possible to use the hat on the rasp, if I want to use the lora end point with it? (the goal is to receive gps location from the end point to the rasp and then transmit it to the network)
I am planning to get one end point (LGT-92) and one LoRa GPS HAT for Raspberry Pi.
The hat will be connected to the Raspberry Pi 4 and used as a gateway. It should receive the location from the end point (LGT-92).
And finally send those acquired data to the network.
Is this architecture possible?
Sorry if my question sound primitive but I am new to this.
