Hi all,
I’m looking for a good antenna cable supplier other than the Aliexpress units, for the 900-915 band.
Are there any good suppliers in US/Canada that are trusted by others?
Hi all,
TLDR; no, but have you considered making your own?
Hi @TC1,
FWIW we have been looking for a steady supplier of high-grade RF cables ourselves in EU for many years and ended up actually making the cables ourselves. The fact is, that no-one really likes to make low-volume orders for low margin products.
I’m not sure what your position is here, but if you make at least a few cables a month I would advise you to buy a crimping tool and make the cables in house. Specifically for sub-GHz frequencies this should be a straightforward process. Also, buying cables and connectors separately you will also gain a lot of knowledge and insight - especially you will start to wonder (if you aren’t already) why is Amphenol N connector 15 USD alone when you can buy the whole cable from Aliexpress for 3 USD.
