Hi everyone,
has anyone managed to do an uplink payload formatter on TTN for the Browan Object Locator?
I have used this but I am not getting correct location information:
var params = {
“bytes”: bytes
bytes = bytes.slice(bytes.length-11);
if ((bytes[0] & 0x8) === 0) {
params.gnss_fix = true;
} else {
params.gnss_fix = false;
// Mask off enf of temp byte, RFU
temp = bytes[2] & 0x7f;
acc = bytes[10] >> 5;
acc = Math.pow(2, parseInt(acc) + 2);
// Mask off end of accuracy byte, so lon doesn’t get affected
bytes[10] &= 0x1f;
if ((bytes[10] & (1 << 4)) !== 0) {
bytes[10] |= 0xe0;
// Mask off end of lat byte, RFU
bytes[6] &= 0x0f;
lat = bytes[6] << 24 | bytes[5] << 16 | bytes[4] << 8 | bytes[3];
lon = bytes[10] << 24 | bytes[9] << 16 | bytes[8] << 8 | bytes[7];
battery = bytes[1];
capacity = battery >> 4;
voltage = battery & 0x0f;
params.latitude = lat/1000000;
params.longitude = lon/1000000;
params.accuracy = acc;
params.temperature = temp - 32;
params.capacity = (capacity / 15) * 100;
params.voltage = (25 + voltage)/10;
params.port=port;
return params;
Hi, Did you manage to get the browan object locater installed? (Interrested because I just bought one and is on it’s way. I am now preparing on how to get it added to ttn)
Were you ever able to get an uplink formatter to work? I’ve been unsuccessful as well.
Are they not GNSS devices? So then you need a GNSS solver.
Have you tried
https://github.com/dasdigidings/the_things_stack_v3_tabs_decoder
itdojo
(Itdojo)
July 4, 2024, 7:38am
5
Try this:
// Initialize params object with bytes
var params = {
"bytes": bytes
// Slice the last 11 bytes from the array
bytes = bytes.slice(bytes.length - 11);
// Check GNSS fix status
} else {
// Extract and mask temperature byte
var temp = bytes[2] & 0x7f;
// Extract and compute accuracy
var acc = bytes[10] >> 5;
bytes[10] &= 0x1f;
bytes[10] |= 0xe0;
// Mask off end of latitude byte
bytes[6] &= 0x0f;
// Combine bytes to form latitude and longitude
var lat = (bytes[6] << 24) | (bytes[5] << 16) | (bytes[4] << 8) | bytes[3];
var lon = (bytes[10] << 24) | (bytes[9] << 16) | (bytes[8] << 8) | bytes[7];
// Extract battery information
var battery = bytes[1];
var capacity = battery >> 4;
var voltage = battery & 0x0f;
// Populate params with extracted and computed values
params.latitude = lat / 1000000;
params.longitude = lon / 1000000;
params.voltage = (25 + voltage) / 10;
params.port = port;
// Return the final params object
return params;
